ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
3D mini-map broken in ACC
2 REPLIES 2
warren_woottonYGATB
166 Views, 2 Replies
When loading a Navisworks NWD file in ACC (acc.autodesk.com/build/files/projects) , the 3D mini-map will not display in first person mode even when navigation setting toggled on.  Mini-map does still work in BIM 360 projects, but not ACC projects.
Labels (2)
2 REPLIES 2
I have found that as well even when using Revit models, sometimes the mini map will launch, sometimes it doesn't.
Thanks for confirming the issue Andy.  I see the mini-map requires a Revit file with levels in the least.  Getting normal functionality now with a Revit file included in the NDW in ACC now.
View short, easy-to-follow videos about how to use Autodesk's construction products.
