This question came in today and I thought it would be nice to post a tip on how to edit your Team Calendar.
If you have already created a Calendar for a project, maybe you typed something wrong, or want to make a quick change to the text.
Let's get started by selecting a project first.
Now click on the dropdown and select "Calendar"
This will open up the Calendar where you can add dates, or modify an existing date.
In this example, lets modify the test on the 12th. If you mouse over this, you will see the icon change to a finger.
This will open up to a new dialog that allows you to "Edit" the date.
Just click on "Edit" and start changing items for the 12th.
Go ahead and make some changes, Name, Start time, End time, even the note on what the event is for. Once you make the changes, then be sure to save them. If you decide you no longer need this date, you can also delete it.
Enjoy the tip and if you have other items you would like to see in the Calendar, be sure to add them to our Idea board.
A360 Idea board:
Thanks and have a great day.
