TIP: How to add a Team Member to a Project as an admin.
Bud_Schroeder_ADESK
Alumni Alumni
Bud_Schroeder_ADESK
How to add a Project Admin to a Project:
If you have a project that you did not create and the person that created it has left, or is not available.  You as the HUB Admin can add an existing HUB Team Member to the project as a "Project Admin".  You want the admin of the HUB to go to the Admin panel.  Then click on "Projects
Expand that project and click on "Manage Roles" and click on "Team Members".
This will bring up the dialog that allows you to add an existing HUB Team Member as a Project Admin to this Project.
TIP:  This works for all project types including Secret.
Next you will see a GREEN banner saying  you have added the Team Member as Project Admin.
Now that person will show up in the project as a Project Admin in that project.
TIP: As the admin, you can add yourself to the project as well.
Hope this helps and have a great day.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
You can also use project roles to restrict how much access certain users or groups have. Unlike groups, which have the same membership throughout your application, project roles have specific members for each project.
