I'm working myself in circles on this one...
A360 isn't recognizing my projects, or I'm not setting them up properly. This also causes Revit to not be able to upload via the Collaborate Tab.
I'm using the trial version if that makes a difference.
Appreciate the help,
Matt
Solved by KyleB_Autodesk. Go to Solution.
I have not used the collaborate tool myself. Have you tried uploaded directly from A360? You can upload to just general data as part of your acount or once you create a project you should be able to go into that project and up load their by clicking the [UPLOAD] button. That should work even as a trial.
I have on a coworker's Hub. We uploaded a Revit file directly through the browser.
It's the worksharing/collaborating through Revit that we can't seem to figure out. I feel like it's tied specifically to the fact A360 doesn't recognize our created project. FYI, our ultimate goal is to get a Workshared Revit file to operate across A360.
Matt
Matt,
This sounds like a similar challenge to another thread -> I'm guessing that your Autodesk ID does not have a Collaboration for Revit entitlement associated with it. Log into the Autodesk Account Portal to verify if you have the entitlement.
This page explains the steps to get up and running with Collaboration for Revit. Let us know if you have any additional issues.
Cheers,
Kyle
Kyle, this is exactly what's going on. I signed up for a trial of A360 Team thinking that was what I needed to test out A360 Collaboration for Revit.
Apparently there is no trial version of C4R...I need to purchase the subscription before trying out the features.
Looks like once I purchase a subscription of C4R, then I can continue with the entitlement setup through our Portal. I will also need to purchase a seperate subscription for A360 Team, for the administration of the Hub/Projects. So **** confusing.
Thank you for pointing this out. Probably saved me another half-day of tail chasing.
Matt
Matt,
First, I'm sorry you've had a frustrating time with all of this; it's never fun to have this type of a first experience. I've got a few things that I'd like to address:
-Kyle
No worries, Kyle. It's people like you that keep the forums a helpful + friendly place.
Matt
If this is all the case, what is the point of having A360 in the first place if you can't collaborate particular version projects??
This is just my opinion, but the purpose of A360 is to share files through an Autodesk platform instead of other cloud-hosted servers. C4R makes collaboration between offices and companies possible in a way that no web-hosted file-sharing platform can accomplish.
IMHO
