When opening various .rvt files from A360, I am receiving the following message:
Project"" failed to regenerate with the latest combination of changes. Please revert to a previous version of the project or contact your service provider for assistance.
Followed by this message after clicking "OK":
An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files.
Has anyone else had this issue? Our project is DOA until this can be resolved.
Hi Geoffrey,
Thanks for posting your question, and welcome to the forum. Can you share with us how this was uploaded to your Team account? For example, are you using Revit Collaboration? Also can you create a SCREENCAST showing what you are seeing and where you are seeing this message?
Please make the SCREENCAST Public so that we can view it and share it with the team if needed.
Autodesk SCREENCAST:
Thanks in advance for getting us more details and a SCREENCAST and have a grat day.
After doing some further research with the team, we found that one of the files was corrupted in some capacity. We backtracked the file to a previous version, and everything works fine now. For the sake of time and effort I am not going to re-create the issue; however, if we run into the circumstance again I will be sure to screencast the instance. Thanks for your reply.
Yes, this happened when working with C4R. Not certain that there was any correlation, but the issue seemed to pop up in conjunction with us beginning our COBie set up with the plug-in.
Thanks Geoff for the update and have a great day.
