I'm publishing a NWD and it take several minutes checking info... (6Mb file). After an hour, the application give me and error and I can not see the information. I tried to publish the same model into DWFx format, but the information do not appear, just geometry (empty of course).
Hi Rafael,
Can you check to see if the file itself is protected in any way? if so, then it won't translate at all in A360.
If so, then just save again as unprotected, re-upload, then it should translate just fine.
Let me know if that is the issue.
I export to NWD... after that I reopen in NW... and saving it again.. and at last it seen I can see the model in a360.
hi Rafael,
Let me know,
