Hi
I try to open sharing link and I have got mes. :Unrecoverable exit code from extractor: -1073741831
Regards
Ludwika
Hi Bud
I try to share public the project from ADF360.
When I click RBM on the project in the data window I have small window with the share public link option , and I get this link : http://a360.co/2hFNzrI .
But when I try to open this link in my browser - OPERA - I get message : Unrecoverable exit code from extractor: -1073741831. Maybe I've done something wrong ?
R.
Ludwika
Hi Bud
I copied this file ( this part with CAM section , not drawing) In the new file the CAM section was deleted - setups is empty , there are not toolpaths.
The Share Public Link option was chosen for this file and I've got link : http://a360.co/2i0tds7.
The link works normally.
It seems that the content of the CAM section created the problems of sharing. I've added one setup and one toolpath in the copied file. After SPL I've got the same link which works normally. I don't understand.
Saving original file without any change is impossible. In the original file I had two setups : first with 3 toolpaths and second with one toolpath. I try with turning. See here : http://forums.autodesk.com/t5/computer-aided-machining-cam/post-processor-fagor/m-p/6755717#M21904
R.
Ludwika
Hi Bud
Sorry for my delay , but I was ill.
Here you are this screen
Thanks Ludwika,
Are you trying to share from Fusion? What happens if you sing out and restart Fusion, does it work then. Let us know and we may need to move you to the Fusion 360 forum.
Thanks for trying and Happy Holidays.
Yes , I'm still trying to share from Fusion. See picture below. Reloading AF360 gives still the same link.
The Link which is generated by the option Share Public Link does not work.
Hi Bud
I think that the file which I try to share is damaged. Because I try to watch it from A360 on the WEEBsite and I have the same message - Unrecoverable exit code from extractor: -1073741831.
I have copy this file without CAM section ( this file can be shared with any problem - the link work and can be opened on A360 also), and I will try to insert two setups like in damaged file .
But I will do it on Saturday ( December 31 st )
I will inform you certainly.
Ludwika
Hi Bud
The file which I tried to share was damaged indeed.
As I wrote in my last post I added the new CAM section to the copy of the file and everything is OK.
I don't know why, but it was enough to delet CAM section end rewrite it once again.
Maybe the error was somewhere in the saved CAM code.
The link below is OK.
