How I use Iframe in wikipages? Is there a code for this? I have tried som examples but it shows nothing at the page....
Once you're editing the wiki page in Autodesk 360, you can use the Embed Media tool to insert your iFrame code. Here's an example:
Best,
C.
I have tried with some websites but could not get it to work.... only with embed code from Box.com... Could you send me a code that works with wikipage?
I tried to copy this code example you show and change url but it shows nothing....
Sorry to hear you're having trouble. The code I used was copied straight from YouTube...no alterations at all. That said, I was able to duplicate what you are expiencing by trying other services, like Prezi.
One of our terrific Dev gurus provided this insight: "Because Autodesk 360 is only accessed over "https", embedding "http" URLs does not show anything, as browsers block such embedding."
He also provided a possible solution: in the iframe's URL, if you insert or replace "http" with “https:” you might be able to get some iframes to work that didn't work previously.
For example, I was able to confirm this by embedding a presentation from Prezi. By default, the URL in the Prezi iframe used "http"...embedding didn't work. I tried embedding the iframe again, by changing that "http" to "https". It worked successfully embed it and view it in a wiki page.
Please try this and let me know how it goes for you? Also interested in learning about all the different services you would like to embed.
