Hi all,
I hope an easy one.
I have a 3D model in the A360 viewer, however, I would like to improve the quality of the environment (add some clouds in the sky and so). I have tried to use the Custom: Mode defined option but nothing appears to select or upload.
Which steps should I follow?
Many thanks
Hi there,
The option you are using is "Model defined" which already by itself explains a lot: the style must be in the model.
I'm not sure how to do that, probably you can just set your IBL environment in Inventor (Are you using Inv?) before you upload the model.
By all means, there shouldn't be a browse button popping up when you select that.
