A360 Forum
Welcome to Autodesk’s A360 Forums. Share your knowledge, ask questions, and explore popular A360 topics.
Does the embed function in A360 expire?
1 REPLY 1
amirsamir92
463 Views, 1 Reply
I recently learned that A360 links, used to share models expire after 30 days, if I embed a model in a website, using the iframe code from A360,  will that stop working after 30 days too?
Tags (2)
1 REPLY 1
in reply to: amirsamir92
Hi there @amirsamir92 ,
Since the iFrame uses the link used to share your file with A360, I would presume that that would be the case. It doesn't explicitly say anywhere if it would expire or not, so therefore I would play it safe and post a copy of the file along with wherever you embed it, therefore having a backup file that people can look at no matter what.
I hope this helps, and If it was the solution to your problem please select " Accept as Solution " so others can find the solution faster!
Have a good one,
Cole
