Hi Christian,
The mobile apps for A360 do not have the ability to delete files. Please go to the desktop website in order to delete what you need. I would suggest submitting this as an idea in the ideas page!
If you consider this post resolved, please choose Accept as Solution so that others can find the answer as well.
Hope this helps!
Cole
i have only used the app to watch files. So what desktop website should i go to and where on the site do i do this, to delete the files from mylist?
//christian
Here is the website https://a360.autodesk.com/
Once you sign in, you will have to select the files/projects you want to archive/delete from the dropdown arrow on the right. I attached an image to help you out with this
Hopefully that should do the trick!
Cole
I'm Glad It helped.
Please select " Accept as Solution on the Comment with the solution in it, as it will help other people find the solution faster.
Thanks!
Please help me, because this way don't work now.
I have uploaded files before New A360 version.
On my Autodesk driver I can't see the projects that uploaded on A360 Android app on my smartphone.
