When I drop SolidWorks 2023 files into Desktop Connector project folders, I get the following error (attached).
If I drop earlier versions of SW files, it works fine.
The parts I'm copying over are simple parts with no external references.
For now I need to use .STEP files, which is not ideal. Are we waiting for Autodesk to catch up to the latest Solidworks version or is this something else?
According to our VAR, you are eligible to install older versions of the SW on same computer, under same OS and use only single instance of it in the version of your choice per given license seat at time. This limits the span of the supported versions by the virtue of OS support for them, but gives at least some option to work with external data that needs to be sent back and forth in native format.
