I HAVE A RVT FILE WITH 2D MODEL LINES FOR AN ENTIRE SITE PLAN. WHEN I OPEN THE FILE IN A360 DRIVE'S VIEWER SOME LINES DO NOT SHOW UP UNLESS I ZOOM IN EXTRA CLOSE AND EVEN THEN THE LINES FLICKER. I'VE RE-UPLOADED SEVERAL TIMES AND EVEN MOVED THE MODEL LINES TO A NEW WORKPLANE THAT IS 1'-0" ABOVE FINISH FLOOR LINE BUT I HAVE THE SAME ISSUE. ANYONE HAVE THIS ISSUE OR KNOW HOW TO FIX?
ADDED IMAGES: THE SECOND IMAGES SHOW HOW CLOSE I HAVE TO BE ZOOMED IN BEFORE I SEE THE LINE. IT'S ACTUALLY JUST THE BOTTOM TWO LINES OF WHAT I CIRCLED. I COULDN'T GET ALL THREE LINES IN THE ZOOM.
Solved by Luciane_Conceicao. Go to Solution.
Thank you for reporting this issue to us.
I am able to reproduce it and am currently investigating.
I will get back to you soon.
Cheers,
Luciane
Luciane Conceição Taylor
Product Support Specialist
Autodesk, Inc.
I have reported this to our engineering team and let you know when I receive an update from them.
Cheers,
Luciane
Autodesk, Inc.
Please click the button "Accept Solution" if this suggestion resolves your issue.
I think this issue has been addressed.
Please upload your file again and check if you have better results.
Cheers,
Luciane
Autodesk, Inc.
