Hi
I have a few files that is stored in fusion 360 which requires web browser to open. When I try to open them, I get the following message saying "You don't have required permission to justify the operation". But I'm the only admin and I can't understand the problem here. I have logged in with the same account. Please help me to fix this.
Also I'm using autodesk access to view files on PC. But i don't see the full list of the projects from fusion 360. I only get to see partial data although I'm the admin for all the projects and i can access them via Fusion 360 app.
Thanks.
Solved by MetalRipper_. Go to Solution.
The problem is with Firefox browser addon. One of the addon is blocking some important script, causing this issue.
The hidden projects are due to Project-type settings which were set to Folder level.
Thanks.
Hi, its really working. thank you for sharing. i appreciate this solution
