We have been using 360 as our drive for the last year about and ever since we upgraded to 2016 across the board our computers are in like a perma-sync state. we use only 2 computers and our files are nothing out of the ordinary. they synced perfectly and quickly before but since we switched it has been causing havoc in our opperation. Is there something that changed that is doing this to us or is there someway to fix this?
mainly using autocad 2016 and occasionally revit. The majority of the files are under 1000 kb, but occasionally we have a 30,000 or 40,000 kb revit file (like once a week) and I understand that the large file would make it take longer but most of the issues we are having are with 1, 2, or 300 kb files. No failures but files will go without check marks for hours when it use to only take 10-15 seconds before we upgraded. The only way to pull it out of a perma-sync is just restart the computer and sync again but doing this constantly between 2 computers is a nightmare.
Hi Jack,
Thanks for the update. Are both computers in the same office? Also can you go to the A360 Drive icon and right click on it. Then click "Preferences" Screen grab that and share it here.
Also what happens if you right click on the A360 icon and click Sync Now? Does that work?
Also for Revit, are you copying the file to the A360 Drive folder so that they sync up to A360 Drive?
Thanks for getting us more details on this.
Yes, both are in the same office currently, but 360 becomes most important to us when one is out of town, which will be happening tomorrow so hopefully we can get this sorted out today. It is a random crap shoot. Sometimes autosync after saving works normally, sometimes it doesn't, sometimes syncing through the icon works, sometimes it doesnt but not more often than not they all lead to issues and the only time every thing gets updated propperly is through a full restart of my computer.
Putting this in perspective I originally saved a 300kb file 5 minutes before my first post and it is still syncing
all of my files now have a green check except the file I saved and others I have worked on since. Since we only have one of us working today
I haven't needed to reboot to get both computers with the same files
The revit files I recieve via email/ drop box from a partner (who doesnt use 360 hence dropbox) then I take copy the file into 360, manually sync, then use only for reference. I do not re-save them once they are in my files.
also to clarify an easy answer would be poor internet speed/connection but all other forms of internet use are still top notch
here is my preference clip
Thank you for all the time and help you are providing
I did this and hit sync and both the folder and the file, as well as all my other files, had green checks by them within
20 seconds and I could find it in my internet drive as well. Even after all the files were checked it the icon on task bar
continues to swirl and say that 360 is syncing still.
Then I tried this again to see if it would sync this folder/file but because it never stops it doesnt seem to realize the file is there
I then restarted my computer to try to get it to sync and it started syncing and and wouldnt recognize this second file/folder
so I had to restart a second time. After this restart it synced within 15 seconds of rebooting.
It seems like it is getting stuck finalizing the sync, because it properly syncs and gives checks on all the files I originally sync but it just never ends it
Im unsure of where to go to make the customization change
but somehow this problem resolved it self I guess because when I
Got here this morning it started working just perfectly again
I didnt make any changes or do anything different
I guess the autodesk gods were just happy with me no
thanks bud for all the time and help
hopefully it keeps working like this
