My local drive is empty although i have 13.4Gb free of my 25Gb available and the icon in the tray says it is syncing.
I have now left my computer on for 48 hours and it is still saying the same.
I have windows 8.1 installed.
can anyone help?
Solved by BrettWright. Go to Solution.
Hi Simon,
This does seem a bit odd, lets see if we can get this figured out for you.
1. Are you sharing any of your A360 Drive Folders, or is anyone sharing any A360 Drive folders with you? There are a few scenarios that might cause this listed below that we should check first.
2. Now a few more basic operational questions.
Hi Simon,
On your last statement, you say that you shut all down and then restarted, however, i'm not sure if that fixed the issue or not here :). Would you please confirm so that I know we still need to assist?
Hi Simon,
Let's have you try the below to see if we can narrow this down a bit.
From your desktop pc machine, can we try to see if SYNC is working manually, without doing a saveas from either of your products?
Then if that works, go to your laptop and force a SYNC Now the same way you did above from the desktop pc, to see if that folder and files get synced back down to your laptop local A360 Drive folders.
Final thought, in case you didn't know, Sync and Revit are NOT connected like ACAD/LT and Sync are, which would mean that SYNC won't automatically sync to your local Revit files to your online web A360 Drive location. You can however, manually drag and drop your Revit files into your local A360 drive folders and then Sync them to the online A360 Drive folders. That will work.
Let me know how this goes for you,
Hi Simon, can you try the below steps?
thanks let us know if this works,
Hi Simon,
Thanks for letting us know that effort worked for you. I'm sorry that you had to do all that manually, however, I am most glad that all is well on both your machines now.
Please let us know if you have any other questions.
