after 19th June, Autodesk will retire A360 Desktop so
- Your Autodesk A360 Drive folder will no longer synchronize with A360 Drive online. However, both your local data and online data remain available.
- Autodesk AutoCAD settings sync will no longer function.
- The Autodesk AutoCAD “Share Document” feature will no longer be available from within the product.
I can continue use normally A360 Drive, isn'it?
Thank you. Regards.
