I keep receiving an error report constantly during the day. This has been occuring for the past 2-weeks & is very annoying.
Anyone else experienced this & have any sulotions yet?
A360 Desktop Version: 6.1.0.1100
I believe it was installed with 2015 Ultimate Building Design Suite.
What is the status on this? I have a user getting this error message although we are not on 360. When he gets the error his system does not shot down. It's just an annoyance and pops up periodically throughout the day. We do however have AutoCAD, Vault and Fusion Lifecycle.
Hi there,
You're replying to a very old thread here, not sure you're having the same issue.
This is the general Autodesk crash screen. Is it A360 that is crashing? Or does it give another program name?
A360 desktop is an app that has been installed with many autodesk applications including AutoCAD. You should have upgraded to the most recent version (9) to be able to keep using it. Can you check on the version of your A360 desktop app?
Btw, if you're not using it, you might just as well uninstall it.
Hope that helps.
Hi Chandler,
Thanks for posting your question. Can you share a screenshot of what you are seeing and when this error comes up? It sounds like you are talking about A360 Desktop Sync component and if so, you may want to take a look at the following link and update it to 9.5, or uninstall it.
A360 Desktop Expiring links and FAQ:
You can also create a SCREENCAST for us, that may be even more helpful.
Please make the SCREENCAST Public so that we can view it and share it with the team if needed.
Autodesk SCREENCAST:
Let us know more details and if this is the case, we can split this out to a new thread on the A360 Drive forum.
Thanks in advance for getting us more details and have a great day.
I piggybacked on the this post because the original poster already attached a screen shot of the very same error my user is having. I did not notice this issue being resolved above when he altered the "sync".
I was trying to Install Inventor 2018 but during the process an error came up
"The cabinet file 'disk1.cab' required for this installation is corrupt and cannot be used. This could indicate a network error, an error reading from the CD-ROM, or a problem with this package."
It gave me the option to abort,retry or ignore... I ignored the problem but a second error came up that said
"2350(FDI.Server Error)"
I just click OK the installation finish but this came up
This could be an issue with the Inventor Installer, you might need to check in the Install and Licensing forum.
Autodesk Install and Licensing Forum:
But... before you do that, you could take a look at the following link and see if installing the latest version of A360 Desktop resolves this.
It's possible that you are seeing this error because the version you have with Inventor is no longer valid.
IF that does not resolve this, be sure to check the Install and Licensing forum.
Hope this helps and have a great day.
