Hi
I am trying to add a flat-pattern-formula via Edit Property in Vault
"=<FLAT PATTERN AREA> cm" |
I add the formula to my custom prop Area via Edit Property in Vault. Area is mapped both ways.
When I open the file in Inventor - without updating properties - I can see the formula is working.
But when I check the file out the file is replaced by the result of the formula - but now it is text and will not change when editing the part.
I have added other formulas in Vault to custom properties this way and it has worked fine - but this has been standard inventor-properties (like =<Title>, =<Part Number>, etc)
Why does it not work with flat-pattern-formulas? Seem to be the same problem with custom properties - if you add a formula with custom properties via Edit properties in Vault...
If I add the formula first in Inventor and check it in to Vault it will alway stay a formula. But I want to add the formula to many files, so it would be very easy and quick to do in Vault... but it don't seem to work...
Any good / crative ideas???
Best regards
TG
Autodesk Inventor/Vault Professional 2021
