If I define a load combination
LIVE=(LL1 + LL2)
and in load types I assign "live" nature to it; when I try to manualy create a combination, say
COMB1 = 1.6 LIVE
and the load factor for "live" is set to 1.6 in the load factor table; ifI select LIVE from the "case list" column and transfer it to "List of cases in combination" column; RSA assigns a factor of 1.0 instead of a 1.6.
Seems to me that RSA does not recognize the nature of the load combination LIVE.
How do I assign the "live" nature to a combination?
Solved by Artur.Kosakowski. Go to Solution.
This should not happen unless you define SLS combination type rather than ULS (1.0 is the default factor for SLS combinations for all loads). I indicated the steps for EC regulation on the attached picture. Mind taht at any moment you can overwrite the default load factor with the 'needed' one.
