I have an error on a model where the message after running the calculation says "linear load has not been applied to a panel".
The only linear loads I have defined are linear 2p loads. Is there an easy way to locate where these loads are on the model?
Thanks for your response.
I believe I have solved the problem. One of the linear 2p loads that was defined was set to zero for all parameters, i.e. size of the load (kN/m), x coordinates, y coordinates, z coordinates etc. This meant it was so small that visually trying to find the location of this load on the screen was not possible.
By doing a structure verification and then clicking on the error to highlight the location of the problem meant it was highlighting a linear load that was 0kN/m and 0m in length.
