Message 1 of 9
04:27 AM
I am a new user of Robot and maybe this is a stupid question but I hope you will be kind enough to reply.
I am performing a seismic LSA on an existing building and I need to include P-Delta effects.
Would it be enough to include the P-Delta on the Load Cases? will that affect the combinations I create from the load cases? Or should I define the P-Delta non-linearity directly to the load combination?
When I do the latter, the combination including the seismic load case from the Linear Static analysis does not converge and crashes with Error 5000.
Thank you in advance and I would really appreciate your help with this!
