Creating Panel with Python win32com/API
Message 1 of 13
After browsing tons of reference codes, I still can't find a way to create panels using API under Python. Could you please provide some pseudo code how to create a panel?
Here's what I think it should look like based on what I learned
# Let's say the contour c is predefined
panelid= RobApp.Project.Structure.Objects.FreeNumber
panel = RobApp.Project.Structure.Objects.Create(panelid)
panel.Main.Geometry = c
panel.StructuralType = 0  # for panel
panel.AnalyzeTTMethod = True
panel.SetLabel(I_LT_PANEL_THICKNESS, "thickness_name")
panel.SetLabel(I_LT_PANEL_CALC_MODEL, "calcmodel_name")
Is the above correct? Am I missing something?
Also, a huge blocker is to create new instance of a class. In Excel VBA, I see people simply do
Dim contour As New RobotGeoContour
How can python do the same thing using win32com? I can't even find IRobotGeoObject class.
Thank you for the help! Really appreciated!
Replies (12)
Message 2 of 13
I figured the solution myself.
To create a new class instance defined in the API using win32com and Python, one has to do the followings:
  1.  Windows Start -> run regedit (Registry Editor)-> HKEY_CLASSES_ROOT : Here shows all the names of COM objects, such as Robot.GeoContour
  2.  In the Python code, the class instance should be declared as:
contour = win32.DispatchEx("Robot.GeoContour")
# DispatchEx ensures having duplicate COM object instances if you want to create multiple class instances
Message 3 of 13
I am also using Win32com and python interface. But i have problem with creating the contour c .
This was my code . But after i run it i dont see a object in my software.
Am i creating a geo contour wrong ? or  (obj.Main.Geometry = c) is it right ??
c= RobotAPILib.IRobotGeoContour
Segment = RobotAPILib.RobotGeoSegmentLine()
Segment.P1.Set(0,0,0)
c.Add(Segment)
Segment.P1.Set(10,0,0)
c.Add(Segment)
Segment.P1.Set(10,10,0)
c.Add(Segment)
Segment.P1.Set(0,10,0)
c.Add(Segment)
c.Initialize
obj.Main.Attribs.Meshed = True
# obj.SetLabel(robconst.I_LT_PANEL_THICKNESS, SlabSectionName)
obj.Initialize
if you dont mind can you share me the code for your contour c. it will help me a lot
Message 4 of 13
kai-hung.changHSCJ3
def create_panel(segments_in_meter, if_edge_x_is_longer):
# windows Start -> regedit -> HKEY_CLASSES_ROOT (All the names of COM objects)
# Have to use DispatchEx to
for s in segments_in_meter:
gsl = win32.DispatchEx("Robot.GeoSegmentLine")
gsl.P1.Set(*s)
contour.Add(gsl)
del gsl
contour.Initialize()
panelid = project.Structure.Objects.FreeNumber
panel = project.Structure.Objects.Create(panelid)
panel.Main.Geometry = contour
panel.Main.Attribs.Meshed = True
if if_edge_x_is_longer:
panel.Main.Attribs.SetDirX(1, 0, 1, 0)
else:
panel.Main.Attribs.SetDirX(1, 1, 0, 0)
panel.SetLabel(I_LT_PANEL_THICKNESS, "ConXTech")
panel.SetLabel(I_LT_PANEL_CALC_MODEL, "ConXTech")
panel.Initialize()
panel.Update()
del contour
Message 5 of 13
I created my contour similar to your code. just that you used for loop i wrote line by line.
Can you verify what is my mistake.
I am not able to see the contour in the software after i run the app.
Message 6 of 13
kai-hung.changHSCJ3
Any error message coming out?
Message 7 of 13
kai-hung.changHSCJ3
You need obj.Update in the end
Message 8 of 13
This is my code .. I dont see any error message
and i dont see contour or slab in application.  Can you help please
import win32com.client
import RobotAPI_Py_lib as RobotAPILib
# instantiates RobotApplication
robapp = win32com.client.Dispatch("Robot.Application")
# constant type library created when Dispatch is run
robconst = win32com.client.constants
# Visualisation and Control
robapp.Visible = True
robapp.Interactive = True
robapp.Window.Activate
robapp.Project.ViewMngr.Refresh
# creates instance of project (only one allowed)
robapp.Project.New(robconst.I_PT_FRAME_3D)
S = RobotAPILib.RobotStructure
S = robapp.Project.Structure
#Label Creation for cross sections
labels = RobotAPILib.RobotLabelServer
labels = robapp.Project.Structure.Labels
# Naming the Slab and Assigning properties of Slab
SlabSectionName = "Slab"
Slab_Label = labels.Create(robconst.I_LT_PANEL_THICKNESS, SlabSectionName)
thickness = RobotAPILib.RobotThicknessData
thickness = Slab_Label.Data
thickness.MaterialName = "MAT1111"
thickness.ThicknessType = robconst.I_TT_HOMOGENEOUS # For Isotropic
thicknessData = RobotAPILib.RobotThicknessHomoData
thicknessData = thickness.Data
thicknessData.ThickConst = 1
labels.Store(Slab_Label)
# Creating the Slab Object
obj_server = RobotAPILib.RobotObjObjectServer()
obj_server = S.Objects
objNumber = obj_server.FreeNumber
obj = RobotAPILib.RobotObjObject()
obj = obj_server.Create(1)
c= RobotAPILib.RobotGeoContour()
c.Add(Segment)
c.Add(Segment)
c.Add(Segment)
c.Add(Segment)
c.Initialize()
obj.Initialize()
obj.Update()
Message 9 of 13
 I think there is a mistake with the way i add segments but i couldnt figureout what it is
Message 10 of 13
kai-hung.changHSCJ3
What looks suspicious to me are these:
Or another possible bug is here:
c.Add(Segment)
c.Add(Segment)
c.Add(Segment)
c.Add(Segment)
In my code, I create a new GeoSegmentLine in each for loop. Maybe you can try the same thing.
Message 11 of 13
The initializations are slightly different between you and me.
Instead of writing project.structure.objects every time i created a variables .
where
S = project.structure
obj_server = project.structure.objects
Message 12 of 13
The code worked when i deleted segment every time before i add a contour segment.
Thanks for the assist
Message 13 of 13
alexander.silvaGA9XG
How to install RobotAPI_Py_lib?
