Seismic Load Generation Robot
chad.corkern
chad.corkern
Thanks in Advance for Advice or help.
In ASCE 7-16 if a storage live load for a floor is high enough, a percentage of that (25%) has to be accounted for in the seismic weight. When generating seismic load in Robot, is there a way to account for that increase?
Also, if I a different Lateral Force Resistance System in each of the two orthogonal directions, is there a way to generate these loads differently in one go?
Chad C.
Simau
Hi @chad.corkern
Yes for both questions:
1)
2)
M. Agayr
chad.corkern
Mr. Simau,
Thank you for your response. I do still have  a couple of questions.
In part 2, how would I tell it that the X and Y direction have different R values?
chad.corkern
Thanks in advance for any help
When trying to generate load combinations in Autodesk Robot I get the attached warning? Can anyone help?
Simau
What method do you use to generate combinations?
M. Agayr
