API Robot Python - Panel
polylouis
Message 1 of 11
polylouis
Hello everyone,
I tried to do add new label for thicknness panel :
label = labels.Create(IRobotLabelType.I_LT_PANEL_THICKNESS,"25mm")
thData=IRobotThicknessData
thData = label.Data
thData.MaterialName = "S235"
thData.ThicknessType = IRobotThicknessType.I_TT_HOMOGENEOUS
homo = IRobotThicknessHomoData
homo = thData.Data
homo.Thickconst = "0,025"
labels.Store(label)
same think on my python script but I have the following error :
thData = label.Data
AttributeError: '__ComObject' object has no attribute 'Data'
Do you have a solution to fix this problem ?
Thank you in advance,
Louis
Replies (10)
Message 2 of 11
Stephane.kapetanovic
hi @polylouis
how did you define the type label, provide previous lines.
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 3 of 11
polylouis
Here is the definition :
import clr
ref = clr.AddReference(
    "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2021\System\Exe\Interop.RobotOM.dll")
from RobotOM import *
from System import *
from System import Environment
app = RobotApplicationClass()
project = app.Project
project.New(IRobotProjectType.I_PT_SHELL)
labels = structure.Labels
Louis
Message 4 of 11
hi @polylouis
As explained, your problem is probably due to not converting the label variable to a RobotLabel type, reason why you cannot access to datas.
label = RobotLabel(labels.Create(IRobotLabelType.I_LT_PANEL_THICKNESS,"25mm"))
Don't do implicit casting with robot API in python try setting explicitly your variable.
Read this thread :
https://forums.autodesk.com/t5/robot-structural-analysis-forum/python-api/m-p/8804010
Best regards
Message 5 of 11
polylouis
Hi Stephane,
Thnak you for your reply !
I have another error:
label = IRobotLabel(labels.Create(IRobotLabelType.I_LT_PANEL_THICKNESS,"E120"))
thData = label.Data
thData.MaterialName = "C30/37"
homo = thData.Data
homo.Thickconst = "120"
labels.Store(label)
File "testrobot.py", line 82, in <module>
homo = thData.Data
Thank a lot for your support,
Louis
Message 6 of 11
hi @polylouis
same issue, label.data and thData.Data returns dynamics vars so cast is necessary.
thData = IRobotThicknessData(label.Data)
homo = IRobotThicknessHomoData(thData.Data)
To understand, try to find topics on boxing/unboxing ___.data returns on multiple types and all are specific that is equal to using same object but recept it in different container declining himself into parts also.
Best regards
Message 7 of 11
polylouis
Thanks a lot for your help. It works !
I would like talk about other subject. On my panel I have a to add several node forces (for example 4)
I did like following example :
case_number = cases.FreeNumber
dl= cases.CreateSimple(case_number, "n1", IRobotCaseNature.I_CN_EXPLOATATION, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
dl_record = dl.Records.Create(IRobotLoadRecordType.I_LRT_NODE_FORCE)
dl_record = IRobotLoadRecord(dl_record)
dl_record.Objects.AddOne(node1)  # select nodes
dl_record.SetValue(IRobotNodeForceRecordValues.I_NFRV_FZ,XXX)
dl_record.SetValue(IRobotNodeForceRecordValues.I_NFRV_FX,XXX)
The only solution I find is to do that for each nodes (ie x4) and combine in a "load combinaison" after
Do you have any ideas to be more efficient about that ?
Louis
Message 8 of 11
hi @polylouis
first close the topic and accept one or several solutions as accepted.
Second create a new thread with new questions in this category.
Best regards
Message 9 of 11
polylouis
Hello everyone !
Alike the creation of label for thickness label I would like to do the same for Reinforcement data.
I have a problem about "Minimum Reinforcement" label :
label_slab = IRobotLabel(labels.Create(IRobotLabelType.I_LT_PANEL_REINFORCEMENT, "REINF_massif2"))
rnfData=IRConcrReinforceData(label_slab.Data)
rnfData.Cover_Bot=XXXX
rnfData.Cover_Up=YYYY
rnfData.SetMainDirection(IRConcrReinforceDirection.I_CRD_ALONG_X,1,1,1)
rnfData.MinimumReinf=IRConcrMinimumReinforcementType.I_CMRT_NONE
All is good (no error given) but the last line is not taken into account..
Do you have any ideas to fix this problem ?
Louis
Message 10 of 11
hi @polylouis
IRConcrReinforceData interface has no property IRConcrReinforceData
Best regards
Message 11 of 11
IRConcrReinforceData interface has no property MinimumReinf. Sorry
