Fixed column base offest
1234eddie
1234eddie
Hi all,
I am trying to put a horizontal spacing between two bolts, in such a way that two bolts are inside the flange (see picture) . But the offset option is not available, and spacing is following an equal pattern. Please find attached the problem and I also attached the picture with what I want to obtain
Gr Edward
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @1234eddie
As far as I know only symmetrical column bases can be defined in Robot. Offset for plate or for bolts group is not supported.
Krzysztof Wasik
