Hi @John_Holtz !
I've done some additional testing today. I have 4 different geometries that i'm analyzing
First batch run consists of:
A) 4 x heat transfer (linear)
B) 4 x non-linear static (@ working pressure) includes the temperature gradients from the previous analyses
C) 4 x non-linear static (@ arbitrary high pressure load that will cause plastic collapse ) includes the temperature gradients from the previous analyses
The .FNO is saved for A) and B), but not for C)
Second batch run consists of only:
The .FNO is not saved for this case either.
I've included TIMEOUT 10 between each analysis
Each non-linear static are set to NOT save incremental output (perhaps this shoul be on?)
The included picture displays all the files for the first geometry:
x5mpqn80j --> heat transfere
hfzg4c5b3 --> non-linear static @ working pressure
3datin2k1 --> non-linear static to plastic collapse
I was hoping to solve ten cases of plastic collapse (as a batch) during the weekend. Great if you can confirm if this is possible or not.
Regards
Sigurd
