Add constraints for an image in a Sketched Symbol
There needs to be the ability to constrain images in a Sketched Symbol, basically the same as in a part sketch. As of Inventor 2013 (and possibly before and after) the only control available is to roughly move the image to where it's needed and leave it there. It seems to break 1 of the founding rules in Inventor of CONSTRAIN ALL SKETCHES. #NeedConsistencyAutodesk
17 Comments
Forgot to include that this should also apply to images used in an IDW title block.
Totally agree with the OP.
It is very difficult to place an image precisely for template purposes. Its just a manual drag and aligning, imagine doing it for creating several templates.
Solutions to this would be appreciated. We are using 2014, so something that could be applied to the older versions would be very helpful.
WCrihfield
     When we are editing a sketch, and we use the insert image button to insert an image, we need to be able to fully constrain that image and place dimensions to its edges, within the sketch environment, for title block sketches, sketched symbol sketches, & other drawing sketches, the way we can in a Part file sketch.
     Thanks for enabling that ability within part file sketches, but what about assembly files.  Why is the insert image button greyed out, while I'm editing a sketch within an assembly file?  Why can't I easily insert an image on either a work plane or the flat face of a component the way I can within a part file?  Please enable this too, and make it work with the images as we can within part files.
Tags (5)
MoshiurRashid
I suggest you put the sketch in a separated sketch profile.
Brandon_Mooney
Just coming here from Inventor 2021, for anyone still looking there are no controls for images yet implemented. Please vote 🙂
Octal7
Yes would definitely like to apply constraints to images in borders and title blocks.
Scottyos
Think this would be a nice feature to implement. It would be very useful on my end. Otherwise I have to remember all the scale factors for all the sketch symbols we use. 😞
Being able to constrain a raster image would most definitely be helpful.
Get out there and vote!
ROakley_Trility
basic functionality missing in ALL Autodesk products
I asked for this in the 90s early 2000s back when i was using Mechanical Desktop and Inventor was still a wee baby
Autodesk suppliers (and a couple of the Yank crowd that came to OZ for demos) would say hey how come your still using MechDT why not use inventor, i would answer when you guys eventually add enough tools to create and annotate a FULL mechanical detail drawing, ill look at using it, as my deliverables back then were 2d drawings and you could not complete a proper detail drawing from inventor till about 2006 when i finally started using it (i had made simulation models of operating cone crushers which was awesome but the annotation tools were like using a box of crayons
so here we are over 20 years later and STILL MISSING BASIC FUNCTIONALITY
great job Autocrap looks like our subscription money is getting put to good use
ali.jahed
Come on Autodesk.....Learn something from AutoCAD!!!!
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-74368]
joe.spearRYE96
This is essential.
even just a node at the top right like text boxes receive would be exponentially better than freeballing the size box.
maybe even two. one at top right and one at top left.
the ability to dim diagonal would scale it essentially, then the sides and top could be resized with precision.
I know its not the easiest to put in but those are my thoughts in this priority.
 1. nodes to constrain to drawing.
 2. nodes for sizing
Yijiang.Cai
brent_e_barbour
It's still not in Inventor 2025 yet 😖
Scottyos
Coming back 4 years after my previous post on this thread. This is still a good idea and would be ever so helpful. Here's to hoping it's in 2027 lol.
brent_e_barbour
It baffles me why there's so much more control over an image in a part file sketch than a drawing file sketch. It seems like the IPT file programmers were on a completely different team, in a different building, in a different country than the IDW/DWG programmers and had absolutely no communication with the other team.
michielLB46K
@Yijiang.Cai so what is the news bro? Are you guys going to implement this?
