I want to use the Filename property in my title block.
But i don't want to see the .dwg extension.
Is it possible to not show the extension?
Solved by jostroopers. Go to Solution.
1 solution would be to use <PART NUMBER> as it seems to always be the same as filename less the extension. That's what I do in my IDW template.
I use the iLogic code: iProperties.Value("Custom", "Filename") = ThisDoc.FileName(False) 'without extens
Now the .dwg is not showing.
