Inventor Forum
Slicing a Sphere
12 REPLIES 12
Message 1 of 13
rcobbjr
3661 Views, 12 Replies
Slicing a Sphere
I am trying to create a part that has a spherical feature. The spherical feature is "sliced" on the front and back to create a flat surface (see Compound Rest Handle Isometric image). Should I use workplanes to slice the sphere? What is an efficient process the slice the sphere. See Compound Rest Handle Front and Compound Rest Handle Back images and compare to the final result in the Compound Rest Handle Isometric image), Thanks.
12 REPLIES 12
Message 2 of 13
JDMather
in reply to: rcobbjr
The easiest way would have been to Revolve the profile as the very first feature before adding the handles.
You could slice that one side but another way would be to start a sketch on each plane and select Project Cut Edges (from pull-down) and then Extrude - Cut the resulting circles pointing away from the center.
Message 3 of 13
Maybe revolve like this.
Message 4 of 13
JDMather
Handle Sketch (assuming making as one part rather than multi-body solid).
Message 5 of 13
JDMather
in reply to: JDMather
Message 6 of 13
JDMather
Second Revolve.
Message 7 of 13
JDMather
Third Revolve (add rectangle to sketch and do this as two revolves - New Solid if needing multi-body for handle).
Message 8 of 13
JDMather
Mirror and add Hole through center.
Message 9 of 13
JDMather
Not tangent.PNGYour attempt does not appear to be tangent.
Message 10 of 13
Unless you modeled it as a multibody part you may find spliting the front gives you results you do not like at all, as the handles will split too. You may in that case have to use an extrude to cut the sphere flat where you need it.
JD's method would work well, but revolve the handle as a seperate body as you will have to add the pin and pin hole to the sketch, which also means the spheres that hold the handles on will also have a flat spot on them for contact surfaces.
Message 11 of 13
Actually the handle spheres may not have a flat spot, on closer inspection of orgininal sketch it appears they just have a hole in them and the handle narrows down to the pin size, the only contact points the start of the pin and edge of hole tinto spheres.
Message 12 of 13
rcobbjr
This was great. I made each of these different features. Doing it like this seems to work better. Thanks.
Message 13 of 13
JDMather
Attach your file here for final check before you turn it in to your instructor.
Smiley Wink
