Ive imported a CATIA part and I'm trying to redraw it in Inventor. I have the main panels and bend rads in but I cannot for the life of me work out how to model the bend reliefs so they are similar to the ones on CATIA. The purpose of all of this is too reduce the bend reliefs that CATIA has produced even further.
Ive added both the original dumb solid from catia and the new inventor model to an assembly and contrained them in line so hopefully you see what I mean.
Any Help would be very much appreciated 🙂
Hi phillip.ramsdale,
The file you attached is an empty assembly file. We'll need the part files also, in order to be able to see your geomtery. If you're having trouble attaching files, you might try adding screen shots as well.
I hope this helps.
Curtis
@phillip.ramsdale wrote:The purpose of all of this is too reduce the bend reliefs that CATIA has produced even further.
You will not be able to do this with the Inventor sheet metal tools.
You will have to do it as a trimmed surface body in Inventor and then Thicken.
Also, I would stay away from Adaptive, and it looks like you are doing too much work.
I assume you did get flat of original
Hi JD,
I've managed to get a flat of the orginal yes. I'm not quite sure how to do the surface body so I will have to look into it. Do I do this in the flat state of folded state? (apologies for lack of knowledge) only recently got inventor after 6 months of using it at college. We havent done much at all on the sheet metal side of things.
I (almost) always model sheet metal parts in the folded state.
This one would be a bit of a challenge.
I noticed that the original was not completely symmetrical and it looked like in your attempt you are making it symmetrical.
The original is actually supposed to be symmetrical. I think it was CATIA deciding to do something different for one reason or another.
What im trying to do is get the basic shap and dimentions and try to blend the reliefs in as much as humanly possible.
