vba code for opening part in the assy
Message 1 of 10
hi,
id like to open and save each part in the assy using vba code..
can someone help me with this...
thank you!!
Replies (9)
Message 2 of 10
robmatthews
Even standard/content centre parts?
Do you want it recursive? That is, do you only want to open, save and close the initial level documents, or do you want to burrow right down into the assembly tree?
This is my signature, not part of my post.
Message 3 of 10
robmatthews
Well, here's something quick and dirty that does what I think you want.  It does not check whether or not a part is Standard/Content centre, and it does not close the assembly document that you start from. It is recursive.
Public Sub OpenSaveAll()
' Written 2013 by Rob Matthews
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim oRefDoc As Document
Dim bFoundRefs As Boolean
Dim iCounter As Integer
If oDoc.DocumentType = kAssemblyDocumentObject Then
    For iCounter = 1 To oDoc.ReferencedFiles.count
        ThisApplication.Documents.Open (oDoc.ReferencedFiles(iCounter).FullFileName)
        Set oRefDoc = ThisApplication.ActiveDocument
        If oRefDoc.DocumentType = kAssemblyDocumentObject Then
            Call OpenSaveAll
        oRefDoc.Dirty = True
        ThisApplication.SilentOperation = True
        oRefDoc.Save
        oRefDoc.Close
        ThisApplication.SilentOperation = False
        Set oRefDoc = Nothing
    Next
MsgBox "Completed."
End Sub
Message 4 of 10
This will open all part document in the assembly, save and close the same.
Public Sub Assy_Part_Save()
    Dim oAssy As AssemblyDocument
    Set oAssy = ThisApplication.ActiveDocument
    Dim oAssyDef As AssemblyComponentDefinition
    Set oAssyDef = oAssy.ComponentDefinition
    Dim oPart As PartDocument
    Dim strPartName As String
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oAssyDef.Occurrences.AllLeafOccurrences
        If oOcc.DefinitionDocumentType = kPartDocumentObject Then
           strPartName = oOcc.ReferencedDocumentDescriptor.FullDocumentName
           Set oPart = ThisApplication.Documents.Open(strPartName, True) 'use False if you do not want to see the open document
           oPart.Save
           oPart.Close
    Next
End Sub
Message 5 of 10
robmatthews
If you use .occurences instead of .referencedfiles, isn't there the possibility that you will open, save and close the same files multiple times, if they are in the assembly more than once?
Message 6 of 10
Yes you are correct. When I tried I used a simple assembly with 3 parts only.
Message 7 of 10
>>>>rob
what does dirty and recursive means??
Message 8 of 10
robmatthews
Recursive means the function calls itself.  That is, it opens each referenced file, and if the file is an assembly, then the function calls itself to start again. In this way, all parts are opened, saved and closed, even when they are buried deep down in sub-assemblies.
I have used "Dirty" in two places: in the description, it means that I just wrote a quick function, without very much error checking or anything like that; it might not be too robust, it might break when it finds unusual situations, and if it does break, it won't do it elegantly, with a user-designed error message.
Within the code itself, I marked each file as dirty, so that Inventor thinks that the file needs a save.
I hope this helps.
Message 9 of 10
ekinsb
Why do you want to open and save each part?  Why not just save each part?  Part and subassemblies don't need to be the active document to be able to be saved and they're already open as a result of being referenced by the assembly.  The easiest way to save all documents referenced by an assembly is to do use the Save2 method of the AssemblyDocument object.  This will save the assembly and all referenced documents that have been edited.
Brian Ekins
Mod the Machine blog
Message 10 of 10
robmatthews
Brian makes a valid point. Why open? If you still want to explicitly save every single file, I have modified my routine to do that. I've added a counter, too.
I don't know enough about Save2 and collections to be able to help with that though.
Option Explicit
Public CountFiles As Long
Sub OpenSaveAll()
CountFiles = 0
Call SaveAll(oDoc)
oDoc.Save
CountFiles = CountFiles + 1
MsgBox "Completed. Saved " & CountFiles & " files."
End Sub
Sub SaveAll(oDoc As Document)
Dim sName As String
        Set oRefDoc = oDoc.ReferencedFiles(iCounter)
        sName = oRefDoc.FullFileName
            Call SaveAll(oRefDoc)
        oRefDoc.Save
    Next
End Sub
