Ilogic move and rename parts
I have a part file XXXXYYYY.ipt and I would like an ilogic code that searches if my file name contains "XXXXYYYY" to replace the X's and Y's with 1244SIMS and moves that file to a specified folder. Is there any code out there that will allow me to do this?
Vladimir.Ananyev
You may consider the huge set of methods in the .NET String class to change filename.
Look at these links:
String Class
http://msdn.microsoft.com/en-us/library/microsoft.visualbasic.strings.aspx?cs-save-lang=1&cs-lang=vb...
Strings in Visual Basic
http://msdn.microsoft.com/en-us/library/hzcd8ze0.aspx
You may use
ThisDoc.Document.SaveAs(NewFileNameAndExtension , SaveCopyAs)
method to save the file with another filename.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Thanks for the quick reply and info. Now, that I have a basic understanding of strings how do I tell my renamed file what path to take? I want my renamed file to save to a certain directory.
Vladimir.Ananyev
Assume
1) the new filename is MyNewFile.ipt
2) you want to save your renamed file to the existing folder   d:\AAA\BBB\CCC\DDD
then your rule could be similar to the following:
'new filename
dim Filename as string = "MyNewFile.ipt"
'target folder path
dim DirName as string = "d:\AAA\BBB\CCC\DDD"
'now you may create the full filename
dim FullFilename as string = DirName & "\" & Filename
'save file
ThisDoc.Document.SaveAs(FullFilename , False)
See also System.IO.Path class details.
Very useful if you need to perform operations on strings that contain file or directory path information.
http://msdn.microsoft.com/en-us/library/system.io.path.aspx
Vladimir Ananyev
Thanks that worked but how do I delete the old folder once my file has been moved?
Vladimir.Ananyev
My advice - use .NET System.IO namespace objects.
In this particular case - Directory.Delete(...) method
http://msdn.microsoft.com/en-us/library/system.io.aspx
Vladimir Ananyev
