Hi John
You should call Document.Views(1).update to , this will force an update even
if inventor is not visible.
Regards
Ishwar
"John W. Cargile" wrote in message
news:306F92818017B13E4D9EB8287F928BB5@in.WebX.maYIadrTaRb...
> How do you get an IDW to update if it is opened in an invisible instance
of
> Inventor?
> I am running Inventor on a web-server through ASP calls but setting the
> ivApp.Visible property to True has no effect. (Inventor will remain
> invisible)
> I have noticed that Inventor, and the IDW, must be visible on screen in
> order for the IDW to update. This is not the case however for modifying
> IPT's.
> I also noticed that the Inventor.DrawingDocument has an Update method that
> throws the error "Object does not support this property or method".
> Has anyone run into this?
> John W. Cargile
> Inventive Solutions
