Installation & Licensing
Revit architecture unstall error
1 REPLY 1
415 Views, 1 Reply
Hello/ When i install revit, i have error/
System Win7 x 64
from log file:
2012/3/31:17:13:57 xxx xxx-PC === Setup started on xxx-PC by xxx ===
2012/3/31:17:13:57 xxx xxx-PC Launch
2012/3/31:17:15:10 xxx xxx-PC === Setup ended ===
2012/3/31:17:13:58 xxx xxx-PC === Setup started on xxx-PC by xxx ===
2012/3/31:17:13:58 xxx xxx-PC Launch
2012/3/31:17:15:11 xxx xxx-PC PageOpen LaunchDialog
2012/3/31:17:18:40 xxx xxx-PC PageOpen LicenseDialog
2012/3/31:17:31:51 xxx xxx-PC PageOpen ProductInfoDialog
2012/3/31:17:33:18 xxx xxx-PC PageOpen ProductSelectionDialog2
2012/3/31:17:34:21 xxx xxx-PC PageOpen FullProgressDialog
2012/3/31:17:34:22 xxx xxx-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): X:\revit2\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\xxx\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/3/31:17:34:42 xxx xxx-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2012/3/31:17:34:42 xxx xxx-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): X:\revit2\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\xxx\AppData\Local\Temp\vcredist_x86_2010.log
2012/3/31:17:34:43 xxx xxx-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/3/31:17:34:44 xxx xxx-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
RK.
Tags (3)
1 REPLY 1
DannyHubbard
The problem and workaround is documented at the following link.
http://upandready.typepad.com/up_and_ready/2012/01/installation-the-case-of-microsoft-visual-c-2010-...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Administrator Productivity
