Installation & Licensing
AutoCAD Civil 3D 2013 and 2012 on licensing server
13 REPLIES 13
Message 1 of 14
781 Views, 13 Replies
Hello, I am an IT specialist for a local company, however my knowledge of Autodesk products is limited and most of what is currently set up was inplace before I arrived in the picture.
We have an AutoDesk licensing server (single) that has been serving AutoCAD Civil 3D 2012 licenses without issue.  We recently purchased some Civil 3D 2013 licenses and when I added them to the .lic file on the server all of the 2012 licenses stopped working.
Note, there are reservations involved in this setup (which theoretically are reservering the 2013 licenses for a group of users).
What is the proper way to add 2013 licenses without breaking the 2012 licenses?
Any and all help is much appreciated.
Adam
13 REPLIES 13
Message 2 of 14
DarrenP
you have to combine them a certain way
http://forums.autodesk.com/t5/Installation-Licensing/Combining-License-Files-for-Subscription-and-No...
DarrenP
Message 3 of 14
in reply to: DarrenP
Thank you for this link. I thought I was combining the files correctly, but now see this:
To properly combine identical products, all license files for that product must be created on the same date.
Am I able to recreate the older 2012 licenses file so that is created on the same date as the 2013?
Message 4 of 14
DarrenP
are these licenses on subscription?
DarrenP
Message 5 of 14
What does that mean or how can I find out? I was handed serial numbers and a product key, but was not involved in the purchasing of anything.
I do feel like I saw that term used somewhere though.
Message 6 of 14
DarrenP
you need to find out all of this first before doing anything else
i suggest you talk to whoever handles purchasing in your company and find out who they brought the licenses from
DarrenP
Message 7 of 14
I believe that they are as my license files have the PACKAGE portion included.
Message 8 of 14
DarrenP
both versions or just one?
DarrenP
Message 9 of 14
Both.
Message 10 of 14
DarrenP
if thats the case the 2013 license will be replacing the 2012 license
so you don't need to do the 2012 license file again just do the 2013 license file and the 2012 licenses will be included
DarrenP
Message 11 of 14
We effectivly have two departments using the licensing server.  One department upgraded to 2013, the other did not.  The department that did only purchased enough 2013 licenses to run on their machines.
The other department did not upgrade their liceses, so still need to access to their 2012 licenses.
From what I can tell, the old .lic file had both subscription license entries in it for both departments and we then used reservations to make sure each department only received their licenses.
Message 12 of 14
DarrenP
if all the licenses are on a current subscription
is their any reason why you can't generate a 2014 license
but keep the products at the version they are at currently
DarrenP
Message 13 of 14
Ah, fair enough.
I didn't quite understand the licensing subscription model (or even know that that is what we have). I did as you suggested (both subscriptions have been updated and registered) and that worked!
Thank you so much Darren for your help. I wouldn't have figured this out without our help.
Message 14 of 14
DarrenP
also make sure you install this hotfix for civil 3d 2012: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17253046&linkID=9240698
DarrenP
Administrator Productivity
