Hi, Experts
In this moment I can't configure the ECO notifications, because my client uses NTLM protocol with his email server instead SMTP. I posted this case in the autodesk support system and they answered that there is no way to change this.
The only way is doing an authentication without user and password, but the security rules of my client doesn't allow this.
Someone with the same problem?
Any advice, will be appreciated.
Thanks!
Are oyu trying to set up your client's Vault for him,.. or are you trying to get notifications from YOUR Vault to go to him?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
It will only work with the SMTP protocol.
Greetings, Irvin
Now, we are implementing Vault with a customer that is ISP too, and we have others that use this authentication protocol (government companies,etc.).
Why?, because the use of SMTP with an email account only, is a very unsecure procedure and it may be used by others to send emails on behalf of other persons, because of that, NTLM windows protocol avoid this potential problem.
I now, that Vault only supports NTLM for windows users. Why not for the server email account too?
I suggest that you include this critical feature for future versions of vault. Large companies with these security standars, for now, I guess can not be candidate for Autodesk Vaul Pro (If ECOs and notifications are required.)
Finally, I suggest that this restriction must be documented in the system requirements for Vault.
Thanks for your help.
Jeamy,
Thank you for you feedback. I have added your question to our IdeaStation.
Please go to the Idea and vote on it.
http://forums.autodesk.com/t5/Autodesk-Vault-IdeaStation/Support-for-NTLM-Protocol/idi-p/3803294
