iLogic: Generate derived part
ddavis
Message 1 of 9
ddavis
I am hoping iLogic or some other method can help me solve this issue. This is not really an issue, but more a time consuming process that I would like to automate. I have created a very simple yet effective  tool for starting a new manifold assembly using iLogic. The rules and windows essentially fill out the size of the block, material type, description, project and part number.
Below I have a hydraulic manifold I have designed and from that I created the final .ipt of the internals. The way I did this (which may not be the best method) was to create a second .ipt matching the LxWxH of the original manifold, next I inserted and aligned both into another .iam file, lastly I derived a third .ipt from a subtraction resulting in the third image below. This is a bit time consuming to create, but has been very helpful in error checking our designs. I would like to see if iLogic is capable of allowing me to automate this so we can easily create these internal flowpath .ipt's for every manifold we design. Is there a resource or something similar someone else has done that could point me in the right direction?
Thanks for any help you may be able to furnish, I really appreciate it.
Darek Davis
Replies (8)
Message 2 of 9
Vladimir.Ananyev
Good case.
iLogic “can” automate this procedure via direct calls to Inventor API objects.  My sample rule implements slightly modified method.  It wasn’t tested much (see screenshot).
Please copy this code into the rule in your manifold  part and run the rule.
Hope it will help you as a good start point for your own “magic” rule.
IMHO for this task it is better to use Inventor API and any .NET developing tool (VB, C#,…).  Really I developed and tested this code in the form of VB.NET EXE application (because Visual Studio has excellent debugger) and only then copied resulting code into iLogic rule with very little modifications.
Sub Main
    'Step 0:  reference to active part
    Dim oSourcePartDoc As PartDocument _
          = CType(ThisApplication.ActiveDocument, PartDocument)
'	Dim oSourcePartDoc As PartDocument = CType(ThisDoc.Document, PartDocument)
    'Step 1:  create outer body Body2 using shrinkwrap
    Dim oOuterPartDoc As PartDocument = ShrinkWrap(oSourcePartDoc)
    'Step 2:  create new part derived source and shrinkwrap bodies
    '         and subtract Body1 (source) from Body2 (outer)
    Dim oResultDoc As PartDocument = SubtractPart(oSourcePartDoc, oOuterPartDoc)
    oResultDoc.Views.Add()
    ThisApplication.SilentOperation = True
    Call oOuterPartDoc.Save()
    Call oOuterPartDoc.Close()
    ThisApplication.SilentOperation = False
    Beep()
End Sub 'Main
  Function ShrinkWrap(ByVal oSourcePartDoc As PartDocument) As PartDocument
    Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
    'active project workspace path
    Dim oProjectManager As DesignProjectManager = ThisApplication.DesignProjectManager
    Dim oActiveDesignProject As DesignProject = oProjectManager.ActiveDesignProject
    Dim WorkspacePath As String = oActiveDesignProject.WorkspacePath
    ' Create new assembly document
    Dim oAssyDoc As AssemblyDocument = CType(ThisApplication.Documents _
        .Add(DocumentTypeEnum.kAssemblyDocumentObject, , False),  _
             AssemblyDocument)
    'assembly definition
    Dim oAssyDef As AssemblyComponentDefinition = oAssyDoc.ComponentDefinition
    'Add the source component
    Dim oMatrix As Matrix = oTG.CreateMatrix
    Dim oOcc As ComponentOccurrence = oAssyDef.Occurrences _
          .AddByComponentDefinition(CType( _
            oSourcePartDoc.ComponentDefinition,  _
            ComponentDefinition), oMatrix)
    oOcc.Name = "Manifold"
    ' create filename for this assembly and save it
    Dim AssyFilename As String = WorkspacePath & "\TemporaryAssy.iam"
'	MsgBox(AssyFilename)
    oAssyDoc.SaveAs(AssyFilename, False)
'	MsgBox("Saved")
    ' Create a new part document that will be the shrinkwrap substitute
    Dim oPartDoc As PartDocument = CType(ThisApplication.Documents _
        .Add(DocumentTypeEnum.kPartDocumentObject, , False),  _
             PartDocument)
    Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
    Dim oDerivedAssemblyDef As DerivedAssemblyDefinition _
        = oPartDef.ReferenceComponents.DerivedAssemblyComponents _
            .CreateDefinition(oAssyDoc.FullDocumentName)
    ' Set various shrinkwrap related options
    oDerivedAssemblyDef.DeriveStyle _
        = DerivedComponentStyleEnum.kDeriveAsSingleBodyNoSeams
    oDerivedAssemblyDef.IncludeAllTopLeveliMateDefinitions _
        = DerivedComponentOptionEnum.kDerivedExcludeAll
    oDerivedAssemblyDef.IncludeAllTopLevelParameters _
    oDerivedAssemblyDef.ReducedMemoryMode = True
    Call oDerivedAssemblyDef.SetHolePatchingOptions( _
            DerivedHolePatchEnum.kDerivedPatchAll)
    ' Create the shrinkwrap component
    Dim oDerivedAssembly As DerivedAssemblyComponent _
        .Add(oDerivedAssemblyDef)
    ' Save the part
    Dim PartFilename As String = WorkspacePath & "\OuterPart.ipt"
    Call oPartDoc.SaveAs(PartFilename, False)
    ' Create a substitute level of detail using the shrinkwrap part.
    Dim oSubstituteLOD As LevelOfDetailRepresentation = oAssyDef _
         .RepresentationsManager.LevelOfDetailRepresentations _
            .AddSubstitute(PartFilename)
    oSubstituteLOD.Name = "OuterBody"
    Call oAssyDoc.Save()
    Call oAssyDoc.Close()
    Return oPartDoc
  End Function 'ShrinkWrap
  Function SubtractPart(ByVal oSourcePartDoc As PartDocument, _
                        ByVal oOuterPartDoc As PartDocument) _
                      As PartDocument
    'create new part
    Dim oDoc As PartDocument = CType(ThisApplication.Documents _
             PartDocument)
    Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
    ' Create the derived part 1 - Source body
    Dim oDerivedPartDef As DerivedPartUniformScaleDef _
          = oDef.ReferenceComponents.DerivedPartComponents _
            .CreateUniformScaleDef(oSourcePartDoc.FullFileName)
    Call oDef.ReferenceComponents.DerivedPartComponents _
          .Add(CType(oDerivedPartDef, DerivedPartDefinition))
    ' Create the derived part 2 - Outer body
    oDerivedPartDef = oDef.ReferenceComponents.DerivedPartComponents _
            .CreateUniformScaleDef(oOuterPartDoc.FullFileName)
    'Subtract bodies
    Dim oColl As ObjectCollection = ThisApplication _
          .TransientObjects.CreateObjectCollection
    Dim oCombineFeatures As CombineFeatures = oDef.Features.CombineFeatures
    Dim oBody1 As SurfaceBody = oDef.SurfaceBodies.Item(1)
    Dim oBody2 As SurfaceBody = oDef.SurfaceBodies.Item(2)
    Call oColl.Add(oBody1)
    Dim oCF As CombineFeature = oCombineFeatures _
        .Add(oBody2, oColl, PartFeatureOperationEnum.kCutOperation, False)
    Return oDoc
  End Function 'SubtractPart
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 3 of 9
ddavis
Thank you for your help with this. Unfortunately I have not been successful getting this to work. I copy and paste this in to an iLogic rule, select "Straight VB Code" from the options and once I run the code I get the following error. Is there something that I am doing incorrect?
Thank you,
Darek
Message 4 of 9
Vladimir.Ananyev
I used Inventor 2013.  The part file with my rule is attached.
Please try it.
Can you upload one of your models?
Vladimir Ananyev
Message 5 of 9
ddavis
I figured out the issue. It turns out that Internet Explorer was adding or subtracting extra data. I installed Chrome and performed the coy and paste and it worked like a charm.
Thank you again for your help with this.
Darek
Message 6 of 9
DeerSpotter
can you provide us a .txt file of the code?
Image and video hosting by TinyPic
See My LinkedIn Profile
Message 7 of 9
ddavis
Attached you will find the code in a text file as requested.
Darek
Message 8 of 9
i need to delete the derived part in Inventor using rules  , can you provide me the code ?
Message 9 of 9
DeerSpotter
wow and it thought i was a noob, see OP ^^^
