Locate name of detail view
Is there a property or method that can control the location of the name for a detail view? For example the picture below. Detail "B" represents the api default. Detail "C" representes where I want to put the text. All the properties, aside from "Name" apparently deal with the detail view itself.
Vladimir.Ananyev
Property DrawingView.Label() returns the reference to DrawingViewLabel object.    DrawingViewLabel.Position()  allows you to get and set the position of the drawing view label.   Try something like this:
  dim CurrentPosition2d as Point2d = MyViewLabel.Position
  CurrentPosition2d.x = <new value>
  CurrentPosition2d.y = <new value>
  MyViewLabel.Position = CurrentPosition2d
 Hope this helps.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
