Hmm... Apparently i can't use your "on error" along with "Try" which i have several times in my code...
I will post the full code now, and maybe somone find something in it.. XD
Note theres alot of test code which is not active, from when im trying something..! and also there are many phrases in Danish, which might confuse you.. 🙂
Sub Main()
iLogicForm.Show ("Rulle konfigurator")
'Declarations
'Følgende forhindrer linjer i at køre hvis parten er supressed-------------------------------------------------------------------------------------
' Dim oAsmCompDef As AssemblyComponentDefinition
' oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' 'Iterate through all of the occurrences
' Dim oOcc As ComponentOccurrence
' For Each oOcc In oAsmCompDef.Occurrences
' Dim oName As String
' oName = oOcc.Name
' oOcc.Suppress (True)
' 'the argument is SkipDocumentSave, in default it is false.
' ' so you can also write as
' 'oOcc.Suppress()
' Next
'Parameter.Quiet = True
Dim oName As String
'Definering af Ekstratætningsstørrelse ----------------------------------------------------------------------------------------------------------------
If AkselDia = "20" Then
Component.Replace("Centertætning:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90075.ipt", True)
Else If AkselDia = "25" Then
Component.Replace("Centertætning:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90076.ipt", True)
End If
'Definering af Standard ruller -----------------------------------------------------------------------------------------------------------------------
If StdRuller = "110-001 - Ø89x380x406 Ø20 2F14" Then
Diameter = "89"
Længde = "380"
Tætning = "Skanroll"
AkselDia = "20"
Akselend1 = "Nøglevide"
Akselend2 = "Nøglevide"
Materiale = "S235"
Ekstratæt = False
Nøglevide = "14"
Nøgledybde = "11"
End If
If StdRuller = "110-005 - Ø89x200x226 Ø20 2F14" Then
Diameter = "89"
Længde = "200"
AkselDia = "20"
Materiale = "S235"
Ekstratæt = False
Nøglevide = "14"
Nøgledybde = "11"
End If
If StdRuller = "110-011 - Ø89x1150x1182 Ø20 2F14" Then
Diameter = "89"
Længde = "1150"
AkselDia = "20"
Materiale = "S235"
Ekstratæt = False
Nøglevide = "14"
Nøgledybde = "11"
End If
If StdRuller = "110-022 - Ø89x465x491 Ø20 2F14" Then
Diameter = "89"
Længde = "465"
AkselDia = "20"
Materiale = "S235"
Ekstratæt = False
Nøglevide = "14"
Nøgledybde = "11"
End If
Component.IsActive("Aksel:1") = True
'Definering af Diameter på rulle ---------------------------------------------------------------------------------------------------
'Ø30
If Diameter = "30" Then
oName = oOcc.Name
'Rulle-1.ipt.RDiameter = "30"
'Rulle-1.ipt.RGods = "1,5"
'Rulle-1.ipt.Neddrejning = "28"
'Rulle-1.ipt.NeddrejDyb = "9"
Try
Parameter (oName, "RDiameter") = 30 'Part1
Parameter (oName, "Indv_diam") = 30-1.5-1.5 'Part1
'Parameter (oName, "RGods") = 1.5 'Part1
Parameter (oName, "Neddrejning") = 28 'Part1
Parameter (oName, "NeddrejDyb") = 8 'Part1
Catch
End Try
Component.IsActive("Lejehus:1") = False
Component.IsActive("Lejehus:2") = False
Tætning = "Ingen"
Component.IsActive("Centertætning:1") = False
Component.IsActive("Centertætning:4") = False
If AkselDia = "10" Then
MessageBox.Show("Aksel diameter kan KUN være Ø8 og Ø12. (er nu sat til 8)", "Aksel Diameter")
AkselDia = "8"
End If
If AkselDia > "12" Then
MessageBox.Show("Aksel diameter kan KUN være Ø8 og Ø12. (er nu sat til 12)", "Aksel Diameter")
AkselDia = "12"
End If
If AkselDia = "8" Then
If Lejehus = "Alm leje og tætning" Then
MessageBox.Show("En Ø8 aksel kan ikke være med alm leje og tætning. (Er nu sat til Kombineret leje og tætningshus)", "Aksel Diameter")
Lejehus = "Kombineret leje og tætningshus"
End If
If Lejehus = "Kombineret leje og tætningshus" Then
Component.IsActive("Leje:1") = False
Component.IsActive("Leje:2") = False
Component.Replace("kombihus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90088.ipt", True)
End If
End If
If AkselDia = "12" Then
MessageBox.Show("En Ø12 aksel kan ikke være med Kombineret leje og tætningshus. (Er nu sat til alm leje og tætning)", "Aksel Diameter")
End If
Component.Replace("leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90044.ipt", True)
End If
End If
If Kraftig_rulle = True Then
'Rulle-1.ipt.RGods = "2"
Try
Parameter (oName, "Indv_diam") = 30-2-2 'Part1
'Parameter (oName, "RGods") = 2 'Part1
Catch
End Try
End If
Next
'RuleParametersOutput()
'InventorVb.DocumentUpdate()
End If
'Ø38
If Diameter = "38" Then
oName = oOcc.Name
'Rulle-1.ipt.Neddrejning = "35"
'Rulle-1.ipt.NeddrejDyb = "25"
'Rulle-1.ipt.RDiameter = "38"
Try
Parameter (oName, "RDiameter") = 38 'Part1
Parameter (oName, "Indv_diam") = 38-2-2 'Part1
Parameter (oName, "Neddrejning") = 35 'Part1
Parameter (oName, "NeddrejDyb") = 25 'Part1
Catch
End Try
Component.IsActive("Kombihus:1") = False
Component.IsActive("Kombihus:2") = False
If Tætning = "Ingen" Then
'Rulle-1.ipt.NeddrejDyb = "11"
Try
Parameter (oName, "NeddrejDyb") = 11 'Part1
Catch
End Try
End If
If Tætning = "Simmerring" Then
'Rulle-1.ipt.NeddrejDyb = "18"
Try
Parameter (oName, "NeddrejDyb") = 18 'Part1
Catch
End Try
End If
If AkselDia < "15" Then
MessageBox.Show("Aksel diameter kan kun være Ø15. (er nu sat til 15)", "Aksel Diameter")
AkselDia = "15"
End If
If AkselDia > "15" Then
AkselDia = "15"
End If
If AkselDia = "15" Then
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90049.ipt", True)
Component.Replace("Simmerring:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90094.ipt", True)
End If
MessageBox.Show("Denne diameter findes IKKE i kraftig version. (Kraftig rulle er nu fravalgt)", "Kraftig rulle")
Kraftig_rulle = False
End If
MessageBox.Show("Kombineret leje og tætningshus kan ikke vælges til Ø38 rulle. (er nu sat til Alm leje og tætning)", "Lejehus")
End If
Next
End If
'Ø50
If Diameter = "50" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 50 'Part1
Parameter (oName, "Indv_diam") = 50-1.5-1.5 'Part1
Parameter (oName, "Neddrejning") = 1 'Part1
Catch
End Try
'Rulle-1.ipt.Neddrejning = "1"
'Rulle-1.ipt.RDiameter = "50"
Tætning = "Ingen"
Component.IsActive("Kombihus:1") = True
Component.IsActive("Kombihus:2") = True
MessageBox.Show("Aksel diameter kan, med kombihus, kun være Ø8, Ø10 eller Ø15. (er nu sat til 15)", "Aksel Diameter")
AkselDia = "15"
End If
AkselDia = "15"
End If
Component.Replace("Kombihus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90089.ipt", True)
End If
Component.Replace("Kombihus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90090.ipt", True)
End If
Component.Replace("Kombihus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90091.ipt", True)
End If
End If
Try
Parameter (oName, "Indv_diam") = 50-2-2 'Part1
Parameter (oName, "Neddrejning") = 47 'Part1
Catch
End Try
'Rulle-1.ipt.Neddrejning = "47"
If AkselDia < "20" Then
MessageBox.Show("Hvis aksel diameter skal være under Ø20, skal kombineret leje og tætningshus vælges. (Er nu sat til Ø20)", "Aksel Diameter")
AkselDia = "20"
End If
If AkselDia = "30" Then
MessageBox.Show("Aksel diameter kan IKKE være Ø30. (er nu sat til 25)", "Aksel Diameter")
AkselDia = "25"
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90050.ipt", True)
Component.Replace("Simmerring:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90068.ipt", True)
Try
Parameter (oName, "NeddrejDyb") = 14 'Part1
Catch
End Try
'Rulle-1.ipt.NeddrejDyb = "14"
End If
If Tætning = "Metaltætning" Then
Try
Parameter (oName, "NeddrejDyb") = 29 'Part1
Catch
End Try
'Rulle-1.ipt.NeddrejDyb = "29"
End If
Try
Parameter (oName, "NeddrejDyb") = 24 'Part1
Catch
End Try
'Rulle-1.ipt.NeddrejDyb = "24"
End If
If Tætning = "Skanroll" Then
Try
Catch
End Try
End If
If Tætning = "SKF Z-tætning" Then
Try
Parameter (oName, "NeddrejDyb") = 21 'Part1
Catch
End Try
'Rulle-1.ipt.NeddrejDyb = "21"
End If
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90047.ipt", True)
Component.Replace("Simmerring:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90069.ipt", True)
Try
Parameter (oName, "NeddrejDyb") = 12 'Part1
Catch
End Try
'Rulle-1.ipt.NeddrejDyb = "12"-------------------------------------------------------------------------------------------------------
End If
Try
Parameter (oName, "NeddrejDyb") = 22 'Part1
Catch
End Try
'Rulle-1.ipt.NeddrejDyb = "22"
End If
End If
End If
Try
Parameter (oName, "RGods") = 3 'Part1
Catch
End Try
'Rulle-1.ipt.RGods = "3"
End If
Next
End If
'Ø57
If Diameter = "57" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 57 'Part1
Parameter (oName, "Indv_diam") = 57-6.3-6.3 'Part1
'Parameter (oName, "RGods") = 6.3 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "57"
'Rulle-1.ipt.RGods = "6,3"
MessageBox.Show("Aksel diameter skal være Ø20 eller Ø25. (er nu sat til 20)", "Aksel Diameter")
AkselDia = "20"
End If
If AkselDia > "25" Then
AkselDia = "20"
End If
Try
Catch
End Try
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Try
Catch
End Try
End If
End If
Try
Parameter (oName, "Neddrejning") = 52 'Part1
Catch
End Try
'Rulle-1.ipt.Neddrejning = "52"
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90051.ipt", True)
Component.Replace("Simmerring:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90070.ipt", True)
Try
Parameter (oName, "NeddrejDyb") = 15 'Part1
Catch
End Try
'Rulle-1.ipt.NeddrejDyb = "15"
End If
Try
Parameter (oName, "NeddrejDyb") = 30 'Part1
Catch
End Try
'Rulle-1.ipt.NeddrejDyb = "30"
End If
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Try
Catch
End Try
End If
End If
If Kraftig_rulle = False Then
MessageBox.Show("Denne diameter findes KUN i kraftig version. (Kraftig rulle er nu valgt)", "Kraftig rulle")
End If
Next
End If
'Ø60,3
If Diameter = "60,3" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 60.3 'Part1
Parameter (oName, "Indv_diam") = 60.3-2.9-2.9 'Part1
'Parameter (oName, "RGods") = 2.9 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "60,3"
'Rulle-1.ipt.RGods = "2,9"
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90067.ipt", True)
Component.IsActive("Centertætning:1") = True
Component.IsActive("Centertætning:4") = True
MessageBox.Show("Aksel diameter kan kun være Ø20. (er nu sat til 20)", "Aksel Diameter")
AkselDia = "20"
End If
If AkselDia > "20" Then
AkselDia = "20"
End If
MessageBox.Show("Denne diameter findes IKKE i kraftig version. (kraftig rulle er nu fravalgt)", "Kraftig rulle")
End If
Next
End If
'Ø63,5
If Diameter = "63,5" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 63.5 'Part1
Parameter (oName, "Indv_diam") = 63.5-2.5-2.5 'Part1
'Parameter (oName, "RGods") = 2.5 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "63,5"
'Rulle-1.ipt.RGods = "2,5"
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90000.ipt", True)
AkselDia = "20"
End If
AkselDia = "20"
End If
Try
Catch
End Try
End If
Next
End If
'Ø70
If Diameter = "70" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 70 'Part1
Parameter (oName, "Indv_diam") = 70-2.9-2.9 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "70"
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90082.ipt", True)
AkselDia = "20"
End If
AkselDia = "20"
End If
If Diameter = "70" AndAlso
End If
Next
End If
'Ø76
If Diameter = "76" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 76.1 'Part1
Parameter (oName, "Indv_diam") = 76.1-2.9-2.9 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "76,1"
MessageBox.Show("Aksel diameter kan kun være Ø20 eller Ø25. (er nu sat til 20)", "Aksel Diameter")
AkselDia = "20"
End If
AkselDia = "20"
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90001.ipt", True)
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90002.ipt", True)
End If
End If
Next
End If
'Ø80
If Diameter = "80" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 80 'Part1
Parameter (oName, "Indv_diam") = 80-5-5 'Part1
'Parameter (oName, "RGods") = 5 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "80"
'Rulle-1.ipt.RGods = "5"
AkselDia = "20"
End If
AkselDia = "20"
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90003.ipt", True)
End If
Try
Parameter (oName, "RGods") = 7.5 'Part1
Catch
End Try
'Rulle-1.ipt.RGods = "7,5"
End If
Next
End If
'Ø89 Pga daglig tale er Diameteren sat til 89 istedet for 88,9
If Diameter = "89" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 88.9 'Part1
Parameter (oName, "Indv_diam") = 88.9-2.9-2.9 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "88,9"
AkselDia = "20"
End If
If Materiale = "S235" Then
MessageBox.Show("Aksel diameter kan kun være Ø20 eller Ø25. (er nu sat til 25)", "Aksel Diameter")
AkselDia = "25"
End If
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90004.ipt", True)
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90006.ipt", True)
End If
booleanKraft = InputRadioBox("Hvor kraftig", "4mm", "6,3mm", booleanParam, Title := "Kraftig rulle")
If booleanKraft = True Then
Try
Catch
End Try
Else
Try
Parameter (oName, "RGods") = 4 'Part1
Catch
End Try
'Rulle-1.ipt.RGods = "4"
End If
End If
Next
End If
'Ø101,6
If Diameter = "101,6" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 101.6 'Part1
Parameter (oName, "Indv_diam") = 101.6-3.2-3.2 'Part1
'Parameter (oName, "RGods") = 3.2 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "101,6"
'Rulle-1.ipt.RGods = "3,2"
AkselDia = "20"
End If
AkselDia = "20"
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90083.ipt", True)
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90084.ipt", True)
End If
End If
Next
End If
'Ø108
If Diameter = "108" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 108 'Part1
Parameter (oName, "Indv_diam") = 108-3.6-3.6 'Part1
'Parameter (oName, "RGods") = 3.6 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "108"
'Rulle-1.ipt.RGods = "3,6"
MessageBox.Show("Aksel diameter kan kun være Ø20, Ø25 eller Ø30. (er nu sat til 20)", "Aksel Diameter")
AkselDia = "20"
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90007.ipt", True)
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90008.ipt", True)
End If
If AkselDia = "25" AndAlso
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90009.ipt", True)
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90119.ipt", True)
Component.Replace("Simmerring:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90087.ipt", True)
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90061.ipt", True)
Component.Replace("Simmerring:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90073.ipt", True)
End If
Try
Catch
End Try
End If
Next
End If
'Ø133
If Diameter = "133" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 133 'Part1
Parameter (oName, "Indv_diam") = 133-3.6-3.6 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "133"
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90010.ipt", True)
If AkselDia < "25" Then
MessageBox.Show("Aksel diameteren skal være minimun 25mm. (er nu sat til 25)", "Aksel Diameter")
AkselDia = "25"
End If
End If
End If
If Diameter = "133" AndAlso
Try
Catch
End Try
End If
Next
End If
'Ø159
If Diameter = "159" Then
oName = oOcc.Name
Try
Parameter (oName, "RDiameter") = 159 'Part1
Parameter (oName, "Indv_diam") = 159-6.3-6.3 'Part1
Catch
End Try
'Rulle-1.ipt.RDiameter = "159"
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90110.ipt", True)
AkselDia = "25"
End If
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90052.ipt", True)
End If
Next
End If
If Diameter = "159" AndAlso
End If
'Definering af Længde på rullen (selve rullens længde) -----------------------------------------------------------------------------------------------
If Diameter < "60" Then
oName = oOcc.Name
Try
Parameter (oName, "RLængde") = Længde - 159 'Part1
Catch
End Try
'Rulle-1.ipt.RLængde = Længde - "2"
End If
Try
Parameter (oName, "RLængde") = Længde 'Part1
Catch
End Try
End If
Next
End If
If Diameter > "60" Then
oName = oOcc.Name
Try
Parameter (oName, "RLængde") = Længde - Measure.MinimumDistance("Work Plane1", "Work Plane2")- Measure.MinimumDistance("Work Plane1", "Work Plane2")'Part1
Catch
End Try
'Rulle-1.ipt.RLængde = Længde - Measure.MinimumDistance("Work Plane1", "Work Plane2")- Measure.MinimumDistance("Work Plane1", "Work Plane2")
Next
End If
'Definering af 6-kant ---------------------------------------------------------------------------------------------------------------------------------
If sekskant = True Then
oName = oOcc.Name
If Diameter <> "50" Then
MessageBox.Show("Du kan kun vælge sekskant til Ø50 rulle (Sekskant er nu fravalgt) ", "6-kant")
sekskant = False
End If
MessageBox.Show("Du kan ikke vælge sekskant alm leje og tætning (Sekskant er nu fravalgt) ", "6-kant")
sekskant = False
End If
booleanseks = InputRadioBox("Udvendig eller indvendig", "Lejehus med Udvendig ", "Lejehus med Indvendig", booleanseks, Title := "6-kant type")
If booleanseks = True Then
Component.Replace("kombihus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90093.ipt", True)
Component.IsActive("Aksel:1") = False
End If
If booleanseks = False Then
Component.Replace("kombihus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90092.ipt", True)
Try
Parameter (oName, "ADiameter") = 15 'Part2
Parameter (oName, "Sekskant") = True 'Part2
Catch
End Try
'Rulle-2.ipt.ADiameter = "15"
'Rulle-2.ipt.Sekskant = True
Constraint.IsActive("LejeAksel:1") = False
Constraint.IsActive("LejeAksel:2") = False
Constraint.IsActive("Sekskant:1") = True
Constraint.IsActive("Sekskant:2") = True
End If
End If
Next
End If
If sekskant = False Then
oName = oOcc.Name
Try
Parameter (oName, "Sekskant") = False 'Part2
Catch
End Try
'Rulle-2.ipt.Sekskant = False
Constraint.IsActive("LejeAksel:1") = True
Constraint.IsActive("LejeAksel:2") = True
Constraint.IsActive("Sekskant:1") = False
Constraint.IsActive("Sekskant:2") = False
Next
End If
'Definering af Aksel --------------------------------------------------------------------------------------------------------------------------------
If Udhæng = True Then
booleanUdhæng = InputRadioBox("Ens udhæng i hver side?", "Nej, jeg vil have forskellige udhæng", "Ja, de skal være ens", booleanUdhæng, Title := "Ens udhæng")
If booleanUdhæng = True Then
If Længde <= "465" Then
UdhængafstL = InputBox("Definer det længste udhæng (Hvis rullen proppes, er dette modsatte ende af proppen)", "Aksel udhæng", "13")
UdhængafstK = InputBox("Definer det korteste udhæng (Hvis rullen proppes, skal denne være standard)", "Aksel udhæng", "13")
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = UdhængafstK + 12.5 'Part2
Parameter (oName, "Afst_lås_spor2") = UdhængafstL + 12.5 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Afst_lås_spor1 = UdhængafstK + "12,5"
'Rulle-2.ipt.Afst_lås_spor2 = UdhængafstL + "12,5"
Else
UdhængafstL = InputBox("Definer det længste udhæng (Hvis rullen proppes, er dette modsatte ende af proppen)", "Aksel udhæng", "16")
UdhængafstK = InputBox("Definer det korteste udhæng (Hvis rullen proppes, skal denne være standard)", "Aksel udhæng", "16")
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = UdhængafstK + 15.5 'Part2
Parameter (oName, "Afst_lås_spor2") = UdhængafstL + 15.5 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Afst_lås_spor1 = UdhængafstK + "15,5"
'Rulle-2.ipt.Afst_lås_spor2 = UdhængafstL + "15,5"
End If
CAkselCenter = (UdhængafstL - UdhængafstK)/"2"
oName = oOcc.Name
Try
Parameter (oName, "ALængde") = Længde + UdhængafstK + UdhængafstL 'Part2
Catch
End Try
Next
nLængde = Længde + UdhængafstK + UdhængafstL
'Rulle-2.ipt.ALængde = Længde + UdhængafstK + UdhængafstL
Else
CAkselCenter = "0"
Udhængafst = InputBox("Definer udhæng", "Aksel udhæng", "13")
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = Udhængafst + 12.5 'Part2
Parameter (oName, "Afst_lås_spor2") = Udhængafst + 12.5 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Afst_lås_spor1 = Udhængafst + "12,5"
'Rulle-2.ipt.Afst_lås_spor2 = Udhængafst + "12,5"
Else
Udhængafst = InputBox("Definer udhæng", "Aksel udhæng", "16")
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = Udhængafst + 15.5 'Part2
Parameter (oName, "Afst_lås_spor2") = Udhængafst + 15.5 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Afst_lås_spor1 = Udhængafst + "15,5"
'Rulle-2.ipt.Afst_lås_spor2 = Udhængafst + "15,5"
End If
oName = oOcc.Name
Try
Parameter (oName, "ALængde") = Længde + Udhængafst + Udhængafst 'Part2
Catch
End Try
Next
nLængde = Længde + Udhængafst + Udhængafst
'Rulle-2.ipt.ALængde = Længde + Udhængafst + Udhængafst
End If
Else
CAkselCenter = "0"
oName = oOcc.Name
Try
Parameter (oName, "ALængde") = Længde + 26 'Part2
Catch
End Try
nLængde = Længde + 26
'Rulle-2.ipt.ALængde = Længde + "26"
Else
Try
Parameter (oName, "ALængde") = Længde + 32 'Part2
Catch
End Try
nLængde = Længde + 32
'Rulle-2.ipt.ALængde = Længde + "32"
End If
Next
End If
End If
'Definering af Constraints -----------------------------------------------------------------------------------------------------------------------------
Constraint.IsActive("Clejehus:1") = False
Constraint.IsActive("Clejehus:2") = False
End If
Constraint.IsActive("Clejehus:1") = True
Constraint.IsActive("Clejehus:2") = True
End If
'Definering af Aksel diameter --------------------------------------------------------------------------------------------------------------------
oName = oOcc.Name
Try
Parameter (oName, "ADiameter") = AkselDia 'Part2
Catch
End Try
Next
'Rulle-2.ipt.ADiameter = AkselDia
'Definering af Låseringsspor ------------------------------------------------------------------------------------------------------------------------
oName = oOcc.Name
Try
Parameter (oName, "Låseringspor") = 0.94 'Part2
Parameter (oName, "Lås_spor_dybde") = 7 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Låseringspor = "0,94"
'Rulle-2.ipt.Lås_spor_dybde = "7"
End If
oName = oOcc.Name
Try
Parameter (oName, "Låseringspor") = 1.1 'Part2
Parameter (oName, "Lås_spor_dybde") = 9.6 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Låseringspor = "1,1"
'Rulle-2.ipt.Lås_spor_dybde = "9,6"
End If
oName = oOcc.Name
Try
Parameter (oName, "Lås_spor_dybde") = 11.5 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Lås_spor_dybde = "11,5"
End If
oName = oOcc.Name
Try
Parameter (oName, "Lås_spor_dybde") = 14.3 'Part2
Catch
End Try
'Rulle-2.ipt.Lås_spor_dybde = "14,3"
Try
Catch
End Try
End If
Next
End If
oName = oOcc.Name
Try
Parameter (oName, "Låseringspor") = 1.3 'Part2
Parameter (oName, "Lås_spor_dybde") = 19 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Låseringspor = "1,3"
'Rulle-2.ipt.Lås_spor_dybde = "19"
End If
oName = oOcc.Name
Try
Parameter (oName, "Lås_spor_dybde") = 23.9 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Lås_spor_dybde = "23,9"
End If
oName = oOcc.Name
Try
Parameter (oName, "Låseringspor") = 1.6 'Part2
Parameter (oName, "Lås_spor_dybde") = 28.6 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Låseringspor = "1,6"
'Rulle-2.ipt.Lås_spor_dybde = "28,6"
End If
'Definering af Akselender -------------------------------------------------------------------------------------------------------------------------
If Akselend1 = "Nøglevide" Then
oName = oOcc.Name
Try
Parameter (oName, "Ende1") = "Nøglevide" 'Part2
Indbyg1 = Nøgledybde
Catch
End Try
Next
'Rulle-2.ipt.Ende1 = "Nøglevide"
Aend1 = "-1F" & Nøglevide
'Indbyg1 = Rulle-2.ipt.Nøgledybde
End If
If Akselend2 = "Nøglevide" Then
oName = oOcc.Name
Try
Parameter (oName, "Ende2") = "Nøglevide" 'Part2
Indbyg2 = Nøgledybde
Catch
End Try
Next
'Rulle-2.ipt.Ende2 = "Nøglevide"
Aend2 = "-1F" & Nøglevide
'Indbyg2 = Rulle-2.ipt.Nøgledybde
End If
If Akselend1 = "Nøglevide" AndAlso
Aend1 = "-2F" & Nøglevide
Aend2 = ""
End If
If Akselend1 = "Udvendig gevind" Then
oName = oOcc.Name
Try
Parameter (oName, "Ende1") = "Udvendig gevind" 'Part2
Indbyg1 = 12
Catch
End Try
Next
'Rulle-2.ipt.Ende1 = "Udvendig gevind"
Aend1 = "-1M" & AkselGevind & " udv."
'Indbyg1 = Rulle-2.ipt.Gevdyb
End If
If Akselend2 = "Udvendig gevind" Then
oName = oOcc.Name
Try
Parameter (oName, "Ende2") = "Udvendig gevind" 'Part2
Indbyg2 = 12 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Ende2 = "Udvendig gevind"
Aend2 = "-1M" & AkselGevind & " udv."
'Indbyg2 = Rulle-2.ipt.Gevdyb
End If
If Akselend1 = "Udvendig gevind" AndAlso
Aend1 = "-2M" & AkselGevind & " udv."
Aend2 = ""
End If
If Akselend1 = "Indvendig gevind" Then
oName = oOcc.Name
Try
Parameter (oName, "Ende1") = "Indvendig gevind" 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Ende1 = "Indvendig gevind"
Aend1 = "-1M" & AkselGevind & " indv."
Indbyg1 = "0"
End If
If Akselend2 = "Indvendig gevind" Then
oName = oOcc.Name
Try
Parameter (oName, "Ende2") = "Indvendig gevind" 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Ende2 = "Indvendig gevind"
Aend2 = "-1M" & AkselGevind & " indv."
Indbyg2 = "0"
End If
If Akselend1 = "Indvendig gevind" AndAlso
Aend1 = "-2M" & AkselGevind & " indv."
Aend2 = ""
End If
If Akselend1 = "Nøglevide og indv. gevind" Then
oName = oOcc.Name
Try
Parameter (oName, "Ende1") = "Nøglevide og indv. gevind" 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Ende1 = "Nøglevide og indv. gevind"
Aend1 = "-1F" & Nøglevide & "+M" & AkselGevind & " indv."
End If
If Akselend2 = "Nøglevide og indv. gevind" Then
oName = oOcc.Name
Try
Parameter (oName, "Ende2") = "Nøglevide og indv. gevind" 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Ende2 = "Nøglevide og indv. gevind"
Aend2 = "-1F" & Nøglevide & "+M" & AkselGevind & " indv."
End If
If Akselend1 = "Nøglevide og indv. gevind" AndAlso
Aend1 = "-2F" & Nøglevide & "+M" & AkselGevind & " indv."
Aend2 = ""
End If
'Definering af størrelsen på gevind ------------------------------------------------------------------------------------------------------------------
If AkselGevind > AkselDia Then
MessageBox.Show("Din Aksel er blevet mindre end gevindet i enden. (Gevind nu sat til M6) ", "Gevind konflikt")
AkselGevind = "6"
End If
If AkselGevind = "6" Then
oName = oOcc.Name
Try
Parameter (oName, "Gevind") = 6 'Part2
Parameter (oName, "UdvGev") = 6 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Gevind = "6"
'Rulle-2.ipt.UdvGev = "6"
End If
If AkselGevind = "8" Then
oName = oOcc.Name
Try
Parameter (oName, "Gevind") = 8 'Part2
Parameter (oName, "UdvGev") = 8 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Gevind = "8"
'Rulle-2.ipt.UdvGev = "8"
End If
If AkselGevind = "10" Then
oName = oOcc.Name
Try
Parameter (oName, "Gevind") = 10 'Part2
Parameter (oName, "UdvGev") = 10 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Gevind = "10"
'Rulle-2.ipt.UdvGev = "10"
End If
If AkselGevind = "12" Then
oName = oOcc.Name
Try
Parameter (oName, "Gevind") = 12 'Part2
Parameter (oName, "UdvGev") = 12 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Gevind = "12"
'Rulle-2.ipt.UdvGev = "12"
End If
If AkselGevind = "16" Then
oName = oOcc.Name
Try
Parameter (oName, "Gevind") = 16 'Part2
Parameter (oName, "UdvGev") = 16 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Gevind = "16"
'Rulle-2.ipt.UdvGev = "16"
End If
If AkselGevind = "20" Then
oName = oOcc.Name
Try
Parameter (oName, "Gevind") = 20 'Part2
Parameter (oName, "UdvGev") = 20 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Gevind = "20"
'Rulle-2.ipt.UdvGev = "20"
End If
'Definering af Indbygningsmål -----------------------------------------------------------------------------------------------------------------
oName = oOcc.Name
Try
Indbyg = nLængde - Indbyg1-Indbyg2
Catch
End Try
Next
'Indbyg = Rulle-2.ipt.ALængde - Indbyg1-Indbyg2
'Definering af tætning --------------------------------------------------------------------------------------------------------------------------------
Tættyp = "Labyrint "
Component.IsActive("Skanroll labyrint tætning:1") = True
Component.IsActive("Skanroll labyrint tætning:2") = True
Component.IsActive("Simmerring:1") = False
Component.IsActive("Simmerring:2") = False
Component.IsActive("SKF Z-Tætning:1") = False
Component.IsActive("SKF Z-Tætning:2") = False
Component.IsActive("Metaltætning:1") = False
Component.IsActive("Metaltætning:2") = False
MessageBox.Show("Du kan kun vælge Skanroll Labyrinttætning til Ø20 aksel. Vælg en anden", "Forkert akselstørrelse")
End If
End If
End If
Tættyp = "SKF-Z. "
Component.IsActive("Skanroll labyrint tætning:1") = False
Component.IsActive("Skanroll labyrint tætning:2") = False
Component.IsActive("SKF Z-Tætning:1") = True
Component.IsActive("SKF Z-Tætning:2") = True
MessageBox.Show("Du kan kun vælge SKF Z-tætning til Ø20 aksel. Vælg en anden", "Forkert akselstørrelse")
End If
End If
End If
Tættyp = "Simm. met. "
Component.IsActive("Metaltætning:1") = True
Component.IsActive("Metaltætning:2") = True
MessageBox.Show("Du kan kun vælge Metaltætning til Ø20 og Ø25 aksel. (Tætning er nu fravalgt)", "Forkert akselstørrelse")
Tætning = "Ingen"
End If
Diameter = "108" AndAlso
MessageBox.Show("Du kan kun vælge Metaltætning til Ø25 aksel i en Ø108 rulle, som ikke er kraftig.", "Forkert akselstørrelse")
End If
If Diameter > "108" Then
MessageBox.Show("Du kan IKKE vælge Metaltætning til ruller større end Ø108. (Tætning er nu fravalgt)", "Forkert akselstørrelse")
Tætning = "Ingen"
End If
MessageBox.Show("Du kan kun vælge Metaltætning til Ø20 og Ø25 aksel. Vælg en anden", "Forkert akselstørrelse")
End If
Component.Replace("Metaltætning:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90081.ipt", True)
CMetaltæt:1 = "1,2"
End If
Component.Replace("Metaltætning:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90078.ipt", True)
CMetaltæt:1 = "0"
MessageBox.Show("Du kan IKKE vælge Metaltætning til Ø50 rulle med Ø25 aksel. (Tætning er nu fravalgt)", "Forkert akselstørrelse")
Tætning = "Ingen"
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = 13 'Part2
Parameter (oName, "Afst_lås_spor2") = 13 'Part2
Catch
End Try
Next
'Rulle-2.ipt.Afst_lås_spor1 = "13"
'Rulle-2.ipt.Afst_lås_spor2 = "13"
End If
End If
End If
If Ekstratæt = True Then
MessageBox.Show("Du kan kun vælge Ekstratætning til Ø20 og Ø25 aksel. (Ektra tætning er nu fravalgt)", "Forkert akselstørrelse")
Ekstratæt = False
End If
End If
Ekstratæt = False
End If
End If
Tættypekstra = "Ekstra tæt. "
Component.IsActive("Ekstratætning:2") = True
Component.IsActive("Ekstratætning:3") = True
Constraint.IsActive("CSimmerring:1") = False
Constraint.IsActive("CSimmerring:2") = False
Constraint.IsActive("CSimmerringX:1") = True
Constraint.IsActive("CSimmerringX:2") = True
Else
Tættypekstra = ""
Component.IsActive("Ekstratætning:2") = False
Component.IsActive("Ekstratætning:3") = False
Constraint.IsActive("CSimmerring:1") = True
Constraint.IsActive("CSimmerring:2") = True
Constraint.IsActive("CSimmerringX:1") = False
Constraint.IsActive("CSimmerringX:2") = False
End If
If Diameter > "57" Then
MessageBox.Show("Du kan ikke vælge Ingen tætning til Ruller over Ø57 (Er nu sat til Simmering)", "Forkert Tætningsvalg")
Else
Tættyp = "Uden tæt. "
End If
End If
Tættyp = "Simm. Gum. "
Component.IsActive("Simmerring:1") = True
Component.IsActive("Simmerring:2") = True
End If
'Definering af låseringsspor ----------------------------------------------------------------------------------------------------------------------
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = 8.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 8.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "8,5"
'Rulle-2.ipt.Afst_lås_spor2 = "8,5"
End If
Try
Parameter (oName, "Afst_lås_spor1") = 15.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 15.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "15,5"
'Rulle-2.ipt.Afst_lås_spor2 = "15,5"
End If
Next
End If
oName = oOcc.Name
Try
Catch
End Try
End If
Try
Parameter (oName, "Afst_lås_spor1") = 22.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 22.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "22,5"
'Rulle-2.ipt.Afst_lås_spor2 = "22,5"
End If
Next
End If
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = 13.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 13.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "13,5"
'Rulle-2.ipt.Afst_lås_spor2 = "13,5"
End If
Try
Catch
End Try
End If
Try
Parameter (oName, "Afst_lås_spor1") = 10.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 10.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "10,5"
'Rulle-2.ipt.Afst_lås_spor2 = "10,5"
End If
End If
Try
Catch
End Try
End If
Try
Parameter (oName, "Afst_lås_spor1") = 30.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 30.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "30,5"
'Rulle-2.ipt.Afst_lås_spor2 = "30,5"
End If
Try
Parameter (oName, "Afst_lås_spor1") = 25.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 25.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "25,5"
'Rulle-2.ipt.Afst_lås_spor2 = "25,5"
End If
Try
Catch
End Try
End If
Try
Catch
End Try
End If
End If
Next
End If
oName = oOcc.Name
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Next
End If
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = 19 'Part2
Parameter (oName, "Afst_lås_spor2") = 19 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "19"
'Rulle-2.ipt.Afst_lås_spor2 = "19"
Else
Try
Parameter (oName, "Afst_lås_spor1") = 33 'Part2
Parameter (oName, "Afst_lås_spor2") = 33 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "33"
'Rulle-2.ipt.Afst_lås_spor2 = "33"
End If
Next
End If
oName = oOcc.Name
Try
Catch
End Try
Else
Try
Catch
End Try
End If
Next
End If
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = 18.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 18.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "18,5"
'Rulle-2.ipt.Afst_lås_spor2 = "18,5"
Else
Try
Parameter (oName, "Afst_lås_spor1") = 32.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 32.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "32,5"
'Rulle-2.ipt.Afst_lås_spor2 = "32,5"
End If
End If
Next
End If
oName = oOcc.Name
Try
Catch
End Try
Else
Try
Catch
End Try
End If
End If
Try
Parameter (oName, "Afst_lås_spor1") = 18 'Part2
Parameter (oName, "Afst_lås_spor2") = 18 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "18"
'Rulle-2.ipt.Afst_lås_spor2 = "18"
Else
Try
Parameter (oName, "Afst_lås_spor1") = 32 'Part2
Parameter (oName, "Afst_lås_spor2") = 32 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "32"
'Rulle-2.ipt.Afst_lås_spor2 = "32"
End If
End If
Next
End If
oName = oOcc.Name
Try
Catch
End Try
Else
Try
Catch
End Try
End If
End If
Next
End If
oName = oOcc.Name
Try
Catch
End Try
Else
Try
Catch
End Try
End If
End If
Try
Parameter (oName, "Afst_lås_spor1") = 17.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 17.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "17,5"
'Rulle-2.ipt.Afst_lås_spor2 = "17,5"
Else
Try
Parameter (oName, "Afst_lås_spor1") = 31.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 31.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "31,5"
'Rulle-2.ipt.Afst_lås_spor2 = "31,5"
End If
End If
Next
End If
oName = oOcc.Name
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Next
End If
oName = oOcc.Name
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Try
Parameter (oName, "Afst_lås_spor1") = 34.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 34.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "34,5"
'Rulle-2.ipt.Afst_lås_spor2 = "34,5"
End If
Try
Parameter (oName, "Afst_lås_spor1") = 37.5 'Part2
Parameter (oName, "Afst_lås_spor2") = 37.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "37,5"
'Rulle-2.ipt.Afst_lås_spor2 = "37,5"
End If
Next
End If
oName = oOcc.Name
Try
Catch
End Try
End If
Try
Catch
End Try
End If
Next
End If
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = 39 'Part2
Parameter (oName, "Afst_lås_spor2") = 39 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "39"
'Rulle-2.ipt.Afst_lås_spor2 = "39"
End If
Try
Parameter (oName, "Afst_lås_spor1") = 40 'Part2
Parameter (oName, "Afst_lås_spor2") = 40 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "40"
'Rulle-2.ipt.Afst_lås_spor2 = "40"
End If
Next
End If
oName = oOcc.Name
Try
Parameter (oName, "Afst_lås_spor1") = Parameter (oName, "Afst_lås_spor1") - 3 'Part2
Parameter (oName, "Afst_lås_spor2") = Parameter (oName, "Afst_lås_spor2") - 3 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = Rulle-2.ipt.Afst_lås_spor1 - "3"
'Rulle-2.ipt.Afst_lås_spor2 = Rulle-2.ipt.Afst_lås_spor2 - "3"
Next
End If
'Definering af Udhæng---------------------------------------------------------------------------------------------------------------------------------
oName = oOcc.Name
Nudhæng = "Udh." & UdhængafstL & "+" & UdhængafstK
Try
Parameter (oName, "Afst_lås_spor1") = UdhængafstK + Parameter (oName, "Afst_lås_spor1") - 13 'Part2
Parameter (oName, "Afst_lås_spor2") = UdhængafstL + Parameter (oName, "Afst_lås_spor2") - 13 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = UdhængafstK + Rulle-2.ipt.Afst_lås_spor1 - "13"
'Rulle-2.ipt.Afst_lås_spor2 = UdhængafstL + Rulle-2.ipt.Afst_lås_spor2 - "13"
Else
Try
Parameter (oName, "Afst_lås_spor1") = UdhængafstK + Parameter (oName, "Afst_lås_spor1") - 16 'Part2
Parameter (oName, "Afst_lås_spor2") = UdhængafstL + Parameter (oName, "Afst_lås_spor2") - 16 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = UdhængafstK + Rulle-2.ipt.Afst_lås_spor1 - "16"
'Rulle-2.ipt.Afst_lås_spor2 = UdhængafstL + Rulle-2.ipt.Afst_lås_spor2 - "16"
End If
Else
Try
Parameter (oName, "Afst_lås_spor1") = Udhængafst + Parameter (oName, "Afst_lås_spor1") - 13 'Part2
Parameter (oName, "Afst_lås_spor2") = Udhængafst + Parameter (oName, "Afst_lås_spor2") - 13 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = Udhængafst + Rulle-2.ipt.Afst_lås_spor1 - "13"
'Rulle-2.ipt.Afst_lås_spor2 = Udhængafst + Rulle-2.ipt.Afst_lås_spor2 - "13"
Else
Try
Parameter (oName, "Afst_lås_spor1") = Udhængafst + Parameter (oName, "Afst_lås_spor1") - 16 'Part2
Parameter (oName, "Afst_lås_spor2") = Udhængafst + Parameter (oName, "Afst_lås_spor2") - 16 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = Udhængafst + Rulle-2.ipt.Afst_lås_spor1 - "16"
'Rulle-2.ipt.Afst_lås_spor2 = Udhængafst + Rulle-2.ipt.Afst_lås_spor2 - "16"
End If
End If
Next
End If
'Definering af prop --------------------------------------------------------------------------------------------------------------------------------
If Prop = True AndAlso
oName = oOcc.Name
Try
Parameter (oName, "Prop") = True 'Part2
Catch
End Try
'Rulle-2.ipt.Prop = True
Component.Replace("Metaltætning:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90085.ipt", False)
Nprop = "Proppet "
Next
Else
oName = oOcc.Name
Prop = False
Try
Parameter (oName, "Prop") = False 'Part2
Catch
End Try
'Rulle-2.ipt.Prop = False
Nprop = ""
Next
End If
'Definering af Kombineret leje og tætningshus -------------------------------------------------------------------------------------------------------
Leje = "Alm Leje. "
Component.IsActive("Leje:1") = True
Component.IsActive("Leje:2") = True
Else
Leje = "Kombihus. "
Tættyp = ""
End If
'Definering af Kædehjul --------------------------------------------------------------------------------------------------------------------------------
If Kædehjul = True Then
oName = oOcc.Name
MessageBox.Show("Der kan Kun vælges Kædehjul til Ø63,5, Ø89 og Ø108 (Kædehjul er nu fra valgt)", "Kædehjul")
Component.IsActive("Leje:3") = False
Kædehjul = False
End If
Kædehjul = False
End If
Kædehjul = False
End If
Kædehjul = False
End If
Kædehjul = False
End If
Kædehjul = False
End If
Kædehjul = False
End If
If Tænder <> "Z15 5/8" Then
MessageBox.Show("Der kan kun sættes 15 Tands kædehjul på en Ø63,5 (Er nu sat til Z15)", "Kædehjul")
Tænder = "Z15 5/8"
End If
If Tænder = "Z15 5/8" Then
Component.IsActive("Kædehjul:1") = True
Constraint.IsActive("CKædehjul:1") = True
Component.IsActive("Kædehjul:2") = False
Component.IsActive("Kædehjul:3") = False
Component.Replace("Kædehjul:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90104.ipt", False)
Constraint.IsActive("LejeRør:1") = False
Constraint.IsActive("LejeRør:2") = False
CAkselCenter = "-25,25"
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90050.ipt", False)
Component.Replace("Simmerring:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90068.ipt", False)
End If
Try
Parameter (oName, "ALængde") = Længde + 49 + 27.5 'Part2
Catch
End Try
nLængde = Længde + 49 + 27.5
'Rulle-2.ipt.ALængde = Længde + "49" + "27,5"
Component.IsActive("Leje:3") = True
CSimmerring = "0"
Try
Catch
End Try
Else
CSimmerring = "14"
Try
Parameter (oName, "Afst_lås_spor1") = 36.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "36,5"
End If
Else
Try
Parameter (oName, "ALængde") = Længde + 49 + 33.5 'Part2
Catch
End Try
nLængde = Længde + 49 + 33.5
'Rulle-2.ipt.ALængde = Længde + "49" + "33,5"
Try
Catch
End Try
Else
Try
Parameter (oName, "Afst_lås_spor1") = 39.5 'Part2
Catch
End Try
'Rulle-2.ipt.Afst_lås_spor1 = "39,5"
End If
End If
End If
If Tænder = "Z23 3/4" Then
MessageBox.Show("Der kan kun sættes 5/8 Tands kædehjul på en Ø89 (Er nu sat til Z15 5/8)", "Kædehjul")
Tænder = "Z15 5/8"
End If
Component.Replace("Kædehjul:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90103.ipt", False)
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90047.ipt", False)
Component.Replace("Simmerring:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90069.ipt", False)
End If
Try
Catch
End Try
'CSimmerring = "0"
Try
Catch
End Try
Else
'CSimmerring = "14"
Try
Catch
End Try
End If
Else
Try
Catch
End Try
Try
Catch
End Try
Else
Try
Catch
End Try
End If
End If
End If
If Tænder = "Z23 5/8" Then
Component.IsActive("Kædehjul:1") = False
Constraint.IsActive("CKædehjul:1") = False
Component.IsActive("Kædehjul:2") = True
Component.IsActive("Kædehjul:3") = True
Component.IsActive("Lejehus:1") = True
Component.Replace("Kædehjul:2", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90105.ipt", False)
Component.Replace("Kædehjul:3", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90105.ipt", False)
CAkselCenter = "0"
End If
End If
If Tænder <> "Z23 3/4" Then
MessageBox.Show("Der kan kun sættes 3/4 Tands kædehjul på en Ø108 (Er nu sat til Z23 3/4)", "Kædehjul")
Tænder = "Z23 3/4"
End If
Component.Replace("Kædehjul:2", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90106.ipt", False)
Component.Replace("Kædehjul:3", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90106.ipt", False)
CAkselCenter = "0"
End If
End If
Next
Else
End If
'Definering af Materiale --------------------------------------------------------------------------------------------------------------------------------
oName = oOcc.Name
Mat = "Stål"
MatUK = "Steel"
Try
Parameter (oName, "RMateriale") = "S235" 'Part1
Parameter (oName, "AMateriale") = "S235" 'Part2
Catch
End Try
'Rulle-1.ipt.RMateriale = "S235"
'Rulle-2.ipt.AMateriale = "S235"
Next
End If
If Materiale = "AISI304" Or Materiale = "AISI316L" Then
oName = oOcc.Name
Mat = "RF"
MatUK = "SL"
Try
Parameter (oName, "RMateriale") = "AISI304" 'Part1
Catch
End Try
'Rulle-1.ipt.RMateriale = "AISI304"
booleanParam = InputRadioBox("Skal rullen være komplet rustfri, eller kun røret", "Alt i Rustfrit", "Kun rulle", booleanParam, Title := "Rustfri")
If booleanParam = True Then
RF = "Fuld RF"
Try
Parameter (oName, "AMateriale") = "AISI304" 'Part2
Catch
End Try
'Rulle-2.ipt.AMateriale = "AISI304"
If Diameter > "60" AndAlso
Diameter < "89" Then
MessageBox.Show("Komplette rustfri ruller findes kun under Ø60 og i Ø89 og Ø159 udgave (er nu sat til Kun rulle)", "Lejer")
booleanParam = False
End If
If Diameter > "89" AndAlso
Diameter < "159" Then
End If
If AkselDia < "12" Then
MessageBox.Show("Ø30 rulle med kombi lejehus kan ikke vælges som komplet rustfri (er nu sat til Kun rulle)", "Lejer")
Try
Catch
End Try
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90099.ipt", True)
End If
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90098.ipt", True)
End If
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90063.ipt", True)
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90097.ipt", True)
End If
End If
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90095.ipt", True)
End If
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90011.ipt", True)
MessageBox.Show("Du kan ikke vælge rustfri leje til Ø20 i Ø89 rulle (er nu sat til Ø25)", "Lejer")
AkselDia = "25"
booleanPara = False
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90064.ipt", True)
End If
Component.Replace("Leje:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90096.ipt", True)
End If
End If
Component.Replace("Lejehus:1", "M:\tegn\Standard bibliotek\90000 Indkøbt standard\90111.ipt", True)
'If AkselDia = "20" Then
'MessageBox.Show("Du kan ikke vælge rustfri leje til Ø20 i Ø89 rulle (er nu sat til Ø25)", "Lejer")
'AkselDia = "25"
'booleanPara = False
'End If
End If
End If
End If
Else
Try
Catch
End Try
RF = ""
End If
Next
End If
'Definering af Nøglevide ---------------------------------------------------------------------------------------------------------------------------
oName = oOcc.Name
Try
Parameter (oName, "Nøgledybde") = Nøgledybde 'Part2
Parameter (oName, "Nøglevide") = Nøglevide 'Part2
Catch
End Try
'Rulle-2.ipt.Nøgledybde = Nøgledybde
'Rulle-2.ipt.Nøglevide = Nøglevide
Next
If Nøglevide >= AkselDia Then
Nøglevide = AkselDia - 1
End If
'Navngivning --------------------------------------------------------------------------------------------------------------------------------------
Kraftig = "Kraftig "
KraftigUK = "Heavy "
Else
Kraftig = ""
KraftigUK = ""
End If
iProperties.Value("Summary", "Title") = "Rulle " & Kraftig & Mat
iProperties.Value("Summary", "Manager") = "Roll " & KraftigUK & MatUK
iProperties.Value("Project", "Description") = Leje & Tættyp & Nprop & Nudhæng & Tættypekstra
iProperties.Value("Custom", "Raavare") = "Ø" & Diameter & "x" & Længde & "x" & Indbyg & "x" & nLængde & "-Ø" & AkselDia & " " & Aend1 & Aend2
'Set alle parters BOM structure til Default ------------------------------------------------------------------------------------------------------
If Component.IsActive("Lejehus:1") = True Then
oCompOcc = Component.InventorComponent("Lejehus:1")
oCompOcc.BOMStructure = BOMStructureEnum.kDefaultBOMStructure
End If
If Component.IsActive("Lejehus:2") = True Then
oCompOcc = Component.InventorComponent("Lejehus:2")
End If
'Gemme ----------------------------------------------------------------------------------------------------------------------------------------------
If Gem = True Then
'set a reference to the assembly component definintion.
'this assumes an assembly document is open.
'Dim oAsmCompDef As AssemblyComponentDefinition
'define the path and file name
Dim sPathandName As String
sPathandName = ThisDoc.PathAndFileName(False)
' Create a new part file to derive the selected part into
'note: kPartDocumentObject is the default template
'you could specifiy a path and file name for a custom template
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
'create the derived assembly deffinition
Dim oDerivedAssemblyDef As DerivedAssemblyDefinition
oDerivedAssemblyDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(sPathandName & ".iam")
'Set level of Detail
oDerivedAssemblyDef.ActiveLevelOfDetailRepresentation = "Konfigurator"
'Set derive style options
oDerivedAssemblyDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsSingleBodyWithSeams
'options:
'kDeriveAsSingleBodyWithSeams
'kDeriveAsSingleBodyNoSeams
'kDeriveAsMultipleBodies
'kDeriveAsWorkSurface
'Create the derived part
Dim oDerivedAssembly As DerivedAssemblyComponent
oDerivedAssembly = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAssemblyDef)
' Break the link
'oDerivedAssembly.BreakLinkToFile()
oDerivedAssembly.SupressLinkToFile()
Gem = False
End If
End Sub
Sub CopyIproperties (ByVal fromDoc As Document, ByVal toDoc As Document)
Dim fromPs As PropertySet
For Each fromPs In fromDoc.PropertySets
Dim toPs As PropertySet
If Not toDoc.PropertySets.PropertySetExists(fromPs.InternalName) Then
toPs = toDoc.PropertySets.Add(fromPs.Name, fromPs.InternalName)
Else
toPs = toDoc.PropertySets(fromPs.InternalName)
End If
Dim fromP
For Each fromP In fromPs
Dim toP
On Error Resume Next
toP = toPs.ItemByPropId(fromP.PropId)
If Err.Number <> 0 Then
toP = toPs.Add(fromP.Value, fromP.Name, fromP.PropId)
Else
toP = toPs(fromP.Name)
If fromP.Value <> Nothing Then
toP.Value = fromP.Value
End If
End If
On Error Goto 0
Next
Next
'AssignNumber:
'GoExcel.Open("M:\tegn\Standard bibliotek\Standard nummer udtagning.xlsx", "80000")
' PreviousNumber=GoExcel.CellValue("B2")
' NewNumber=PreviousNumber+1
' GoExcel.CellValue("B2") = NewNumber
' iProperties.Value("Project", "Part Number") = GoExcel.CellValue("C2")
'If question = vbYes Then
'GoExcel.Open("M:\tegn\Standard bibliotek\nummer udtagning.xls", "80000")
' PreviousNumber=GoExcel.CellValue("A2")
' GoExcel.CellValue("A2") = NewNumber
'Else End If
'GoExcel.Save()
End Sub
