AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
AutoCAD Mechanical in "DOS" mode
5 REPLIES 5
elaine.chan
952 Views, 5 Replies
I'm using AutoCAD Mechanical 2013. I attempted to open igs & stp files with Inventor Fusion. The result, many common used functions in Mechanical has become DOS mode.
Eg. When I key in saveas, it will prompt me on the command line to sellect which version, then key in the entire path of the new file to be kept.
Can some experts share how to resolve it? MTIASmiley Sad
5 REPLIES 5
DarrenP
in reply to: elaine.chan
fileDia  press enter then type in 1
try typing that into the command line
DarrenP
elaine.chan
You're a god sent! Issue resolved! Thanks a million!
Can share what the problem was? Wanna learn more....
elaine.chan
in reply to: DarrenP
Another issue: I can't open the Layer manager dialog box Smiley Indifferent
It prompted me to enter Layer/Object keys
nannerdw
Type CMDDIA and set it equal to 1.
elaine.chan
in reply to: nannerdw
A million thank you! Regards Elaine
Edited by
Discussion_Admin
