i tried to print a drawing and it said configuration cannot be used for thefollowing reasons: either driver not found or driver has problem or device cannot be found. however i can print everything else except when i am using autocad?
I completed a drawing and tried to print it.I got a pop up that said configuration could not be used. I have no idea what configuration was used. All i know is that i can print all day long when i'm not in autocad. if gave me 3 options
driver not found
driver has a problem
when I hit the drop down to choose my printer, the printer that i am connected to wasn't even listed, however like i said if i print in any other program my printer is listed and it works HELPPPPPPPPPPPP
the hide systems printer box was not checked and my printer still doesnt appear in the drop down box when tring to print HELPPPPPPP
Could you post screenshots of "Devices and Printers" window (you can start it from Windows Control Panel) along with screenshot of alert message you receive when you trying to print?
Maxim
And your printer is....?
The driver installed in Windows is...? It's version? Is it a server-based driver, or installed on your PC?
Your Windows version?
AutoCAD LT version?
Add-a-plotter wizard? Page Setup manager?
