3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Which settings should i do to achive this tyre rubber? (Vray)
4 REPLIES 4
afsezen
375 Views, 4 Replies
thank you already.
4 REPLIES 4
RobH2
in reply to: afsezen
It isn't a setting, it's a process. There it no automatic modifier to create tire tread. Here's a Google Search for 'creating tire treads.'
https://www.google.com/search?q=3d+tire+tread+tutorial+youtube&sxsrf=AB5stBhQiyQZjaWPP26Qg68C0AaY5sr...
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
afsezen
in reply to: RobH2
sorry there is an misunderstanding because of me. I already create the tire. just cant make it the material correctly look like that.
CAMedeck
The VRayMat has a rubber material preset that would give you a good start.  One thing to keep in mind is that the image you posted has lighting and possibly bounce cards to get the reflections and colors looking just right.  So even the material applied to those tires will likely not look as good with a more basic lighting setup and nothing to reflect.
Chris Medeck
RobH2
I would go online and Google "rubber material 3ds Max' or something if you don't have much experience making your own materials.
Otherwise, Rubber is pretty simple. It's a very, vary dark gray, not completely black, with a tiny bit of reflection and low glossiness. A small amount of noise in the 'Bump' map might help as well.
Learning to make materials is very important to your success in 3d. I'd recommend, just make a black material in Arnold and start an interactive render. Then light your scene and tweak the material every way you can think of till it looks right. In the end, you'll come up with a nice rubber tire material and learn a lot along the way.
Rob Holmes
