Weird texture mapping
I have a nice vertical cladding texture which I've applied to the exterior of a model. It is a flat wall with windows and doors cutout.
It works fine on all the walls, except the one in the screenshot.
The texture warps as it crosses different faces. I don't understand why, because the other walls have similar faces (only windows, no doors).  Although the others don't have the break in the bottom edge where the door is removed.
fla3d
You need to put an UVW map on it and adjust it as you need, when you change a model like this you need to correct the mapping.
