Hi All
I purchased a scene from Cgtrader today.
Im using max 2018 basic.
It was created in vray.
So the first thing I get is missing dlls?
Then after pressing Open I get No textures in viewport.
After getting materials from selected ....
The materials are black and display missing materials
When I click on the material there are no links at all.
How do I get around this?
Solved by Francisco_Penaloza. Go to Solution.
There is no problem it's normal because Vray is not installed on your PC. You have the modeling but not the materials. Each object has a Vray material that you can not see but you can change with a "scanline" or "MentalRay" or "Arnold" or other material depending on your rendering engine
One way to tackle this would be to use the new material converter in Max 2018 and change all material to Physical materials or standard material, depending on what render engine you will use. If this does not work, download the demo of VRay, installed it and then try changing the materials again.
Then there is a script for 3D Max that is called Relink Bitmap with this script you will be able to relink all textures and missing part of your scene.
Remember to give some love to the developer, this script is a life saver.
Regarding purchasing Online, most of that website gives you the option to choose what render engine the scene is prepared for, take a look at yours maybe you have something more friendly with your workflow.
Hello @matt.wilmot and welcome to the community,
I wanted to check in here and see if you resolved this issue with your model. Are you all set now? If not, is there anything I can do? I'll answer any questions you may have and help in any way possible. Thanks!
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @matt.wilmot,
I just wanted to follow up here, any progress on this issue?
Best Regards,
