Vray Glass material
Vray Glass material
Message 1 of 8
Vray Glass material
Need help on the my issues, i am using Vray as renderer and using vray material, i have created a glass material with the help of a post on another forum, its good but i am getting weired reflections coming from inside, can any one suggest what i am missing?
Replies (7)
Message 2 of 8
Diffus3d
I'm guessing your glass is just a plane, give it some thickness with a shell modifier and should be better.
EDIT:  Also, you need refraction for glass.  Looks like it's set to black, so I'm not sure how you are actually getting refraction here.  Strange. Try setting it to white, like 250.
Message 3 of 8
kgokhangurbuz
Hi;
Your glass to be material is missing refraction which is a must.
Please try these:
-Set reflection to pure white
-Set reflection glossiness to 1.0
-Set refraction to pure white
-Set refraction glossiness to 1.0
-Check "Affect Shadows" option ON under refraction parameters.
-Set the glass color via Fog Color parameter under Refraction options (optional).
After applying these, share another rendering with me so i can give you further information if you are not satisfied with what you achieve.
Regards;
Message 4 of 8
Fahad_ALAsmari
Remember glass it has different types the glass material you have made maybe it will work better for cup or window for example the tutorial that you follow maybe it was aiming for different type of glass, this type of glass material is not gonna work for your car glass.
Message 5 of 8
Figster1962
kgokhangurbuz your post was most helpful to me, thank you.
Message 6 of 8
Hello, I checked your "Polo5.jpg ‏307 KB" image, I think that is not a reflection from inside, that is because of IOR which comes under refraction tab. I think that IOR must be set to 1.6 or something by looking at your image (inner interior / seat) distortion... just try set it to 1.01 or 1.02 and see the shader display icon where we can see how shader will look as a result. I think this can fix your distortion issue and will look like a glass.
Even one more thing I would like to add..
To create a realistic car glass effect, you can add "VRay Fresnal" in your reflection color (image input) and adjust start and end color accordingly as black and white until you get the desired effect.
Message 7 of 8
laomusic_arts
It all depends on what kind of glass.
Here are some useful ones (Glass & IORs):
Glass 1.500 -
Glass, Albite 1.489 -
Glass, Arsenic Trisulfide 2.040 -
Glass, Crown 1.520 -
Glass, Crown, Zinc 1.517 -
Glass, Flint, 29% lead 1.569 -
Glass, Flint, 55% lead 1.669 -
Glass, Flint, 71% lead 1.805 -
Glass, Flint, Dense 1.660 -
Glass, Flint, Heaviest 1.890 -
Glass, Flint, Heavy 1.655 -
Glass, Flint, Lanthanum 1.800 -
Glass, Flint, Light 1.580 -
Glass, Flint, Medium 1.627 -
Glass, Fused Silica 1.459 -
Glass, Pyrex 1.474
Enjoy!
Message 8 of 8
It does help me, thanks
