3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Vray environment map shadow
0 REPLIES 0
Message 1 of 1
MartinRNC5W
265 Views, 0 Replies
Hi all,
I am pretty new to 3ds max and vray and have a question where I cant seem to find a good answer:
I am using 3ds max and vray with a bitmap as an environment map. This map has one bright spot (in this case sunlight) but there seem to be minimal shadows from that sun. For my case I don't want to use any other lights in the scene, just would like to know if there is a setting so that the sun in the env. map is used as the main light source.
For comparison i have the same scene setup in blender cycles and there you can see how i expect it to look like.
Here is an example scene. First one is 3ds max second is blender.
3ds max / vray3ds max / vrayBlender / cyclesBlender / cycles
Thanks for the help in advance.
Labels (4)
0 REPLIES 0
