Can anyone help me make the viewport match (even similar to) what Arnold is rendering? The scene below is a simple plane with a JPG material. Top view is VIEWPORT, with blown-out exposure. The bottom is Arnold renderview, which looks fine. Any help is greatly appreciated!!
Solved by truckexpert. Go to Solution.
Solved by darawork. Go to Solution.
Similar question asked here: https://forums.autodesk.com/t5/3ds-max-shading-lighting-and/quot-smooth-highlight-quot-view-too-brig...
Would the solution provided there work in your case?
If not, there are quite a few other threads to perhaps help you out:
https://www.google.com/search
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Thank you kind sir! That worked.
