Hi, this "problem" is related to the file format settings when you export the image.
For example, with TIFF files, you can untick Store Alpha Channel in the settings. By forcing no alpha channel, you should see your blue sky. But of course, if you absolutely need the alpha channel, you will need to do some composition.
MR Sky or Vray Sky, like background colors are considered transparent.
