- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi.
I'm playing around in with the toon shader in Arnold.
Been going through the sample Sophie, but the Stylized Highlight , does not seem to work in 3dsmax
From the sample "Create a directional (distant) light and angle it in a similar position to the physical_sky (you will need to do this by eye).
Under stylized_highlight enter the name of the directional light (this may vary according to which Arnold plugin you are using.) Check the toon documentation for the correct naming convention. For example, in MtoA it would be directionalLightShape1
Increase the size of the stylized_highlight to around 0.2."
So I have made a highlight that is called ArnoldLight002, it is a distance light, and put the name of it in the tonnshader stylized highlight , adjusted the Specular Weight and Roughness, but nothing happens, like in the video for the same tutorial for Maya
Do I have to rename the light something else ?
Do I have to have some specific name ?
Is it broken or am I doing some thing wrong ?
Im on 3dsmax 2025,3, have also tried on 3ds 2024, but the same nothing.
Jonmundur
